NMS Wireless controller 3rd party
‎04-15-2020 12:13 PM
Hello,
I have NMS-ADV-10 but I need to know it does support 3rd party wireless controller and APs?
Thanks
‎04-15-2020 02:19 PM
As Ronald mentioned, it depends on what you need and what you want.
With scripting and workflows in the XMC, you can automate your daily tasks.
If your wireless controller does support SNMP monitoring then you can have flexviews to see what is the status of your APs, clients…
‎04-15-2020 12:39 PM
Yes&No.
Are you able to integrate it so you are able to config it = no
Could you add it as a 3rd party SNMP device to check status and i.e. port counter = yes.
-Ron
