Problem archiving with NetSight 6.1 - File not found/Missing - Config File is empty
Marco_Lorenz
New Contributor II
Hello together,
I have a problem with backing up configs using NetSight 6.1.
We have a lot of devices running Extremeware 7.8e2 (Summit 200-48, Summit 400-48 and so on). The rest of our Devices are running on XOS 15.3.1.4-patch1-41. Both Versions are grouped in NetSight with the names Extremeware and XOS.
When I try to make a backup, most of the devices are working fine. But some of them are telling me "File not found/Missing".
Anyone an idea why?
Kind Regards
Marco
5 REPLIES 5
Marco_Lorenz
New Contributor II
Solved by Comment No. 1
StephenW
Marco, I also had a problem like this. Go into archive management, and click on the general tab of your archive. I changed "Process groups" to 1 and mine archived fine. It's slow but it works.
Hope that helps.
_up__bb_
New Contributor III
Ciao Marco
This is my experience ...
To back up ExtremeWare you can use the script "Alpine - TFTP" already present in version 6.2.0.199 of NetSight.
But the script for ExtremeWare (Alpine - TFTP) fails when trying to copy a file on tftpserver not enabled to write new files.
To enable writing files should be changed the configuration file tftpserver.
/usr/local/Extreme_Networks/NetSight/services/nstftpd.cfg
you can add
-c -d "/tftpboot"
root@netsight:/usr/local/Extreme_Networks/NetSight/services$ ./nstftpd --help
Usage : tftpd [-v][-c][-d dirname][-p pidfilename][-trace][-debug] [-fg]
-v print version and exit
-c allow tftpd to create uploaded files
if they do not already exist.
-d use the specified dirname as the base
where tftpd will look to read/store files
-p use the specified pid file name to store
the pid of the process
-fg run tftpd in the foreground rather than
as a daemon
Restart the tftpd server
/etc/init.d/nstftpd restart
and after check that the new option was correclty setted up
root@netsight:/usr/local/Extreme_Networks/NetSight/services$ ps axf | grep tft
4071 ? S 0:00 /usr/local/Extreme_Networks/NetSight/services/nstftpd -c -d /tftpboot -p /var/run/nstftpd.pid
Now the backup of Extremeware named "Alpine -TFTP" is working for me ...
Stil not work only on BlackDiamond beacuse the cli assume "primary" or "secondary" that was not issued by the script.
Ciao
Roberto
