"Useless Protocols/Applications/Servers" and Analytics Licensing
LeoP1
Contributor
Hi Guys,
I'm working on a customer's Analytics PoC and after get it running for a few days we could measure how many flow licenses they need... (deployed in Overlay mode, with PV-FC-180).
The customer's network is generating around 260K flows/min (EMC Analytics License usage graph)
But we discovered that the 2 TOP applications by flows in the customer's network are DNS and SNMP, followed by MS SQL Server.
Taking a closer look, as shown by EMC the number of flows in 1 hour timeframe (this is a consistent number if you extend the timeframe to days) is DNS=1.7M, SNMP=1.2M (the customer uses other SNMP applications than EMC for specific monitoring of devices) and SQL=950K (prodution databases).
With these numbers, we need 300K licenses for Analytics (which obviously costs money)... But DNS and SNMP statistics (flows) aren't a concern for the customer (useless information), and are consuming Application licenses.
I was thinking about how can I exclude/ignore these types of flow from the Analytics workload, which could allow the customer to buy it.
I found this article https://extremeportal.force.com/ExtrArticleDetail?an=000082263 but I don't know if this only excludes the data from reporting (even using the Application Licensing) or it ignores these flows (and don't count as license usage).
Also, I don't know if including in the policy mirror some rules denying these protocols (as I do for GRE) could prevent the Netflow records being generated for the Analytics Engine on the PV-FC-180, saving this licensing needs.
Any ideas?
Best regards,
-Leo
14 REPLIES 14
Sorry. This is on EOS devices, like N-Series/S-Series. not XOS. not sure but I think policy implementation uses the ACL engine on XOS.
This is only for a policy mirror. IIRC, you should be able to use policy to filter ingress traffic before sending to the port mirror process (which is a different internal process than the policy mirror).
LeoP1
Contributor
Hi Karthik,
Thanks for your idea! I was thinking and trying to figure out a way to do that, and this could be the way...
Making things simpler: The customer have an X670-G2 as a Core and mirrors all traffic to the port 1:31, where the PV-FC-180 is connected.
configure mirror Analytics-DC1 to port 1:31
enable mirror Analytics-DC1
configure mirror Analytics-DC1 add port 1:1-30 ingress-and-egress
configure mirror Analytics-DC1 add port 1:33-47 ingress-and-egress
configure mirror Analytics-DC1 add port 1:53 ingress-and-egress
configure mirror Analytics-DC1 add port 2:1-47 ingress-and-egress
configure mirror Analytics-DC1 add port 2:53 ingress-and-egressI'm not sure on how about to do it... Please, correct me if I'm in the wrong way: I was thinking about creating an ACL and apply it on the egress direction of port 1:31... There's a sample of my idea:
entry deny_snmp{
if{
protocol udp;
destination-port 161;
} then {
deny;
config access-list mirror port 1:31 egress
Do you think it could work?
Best regards,
-Leo
John_Romero
Thanks Leo, hope you're able to find your solution before we implement our POC, I really don't want to have to consider that traffic in my pricing.
Karthik_Mohando
Hi Leo,
Dropping packets using Access list on the egress direction (mirror to port) on the choke points, is that an option?
