‎12-14-2018 09:45 AM
Hi Community
In the past couple of years we have deployed a few Purview installation, using S series switches.
The deployment guides provided with Purview was great!!.
It had detailed information around deployment options with S series switches, listing the exact commands ect for each deployment option.
You could have basically just followed this deployment guide line for line and all would be working in 5 to 10 minutes.
I recently wanted to start testing Extreme Analytics (Purview) with some EXOS switches, VOSS Switcthes in my LAB.
Looking at the config guides ect we see very little to no documentation on the setup required for EXOS, VOSS or even SLX.
Does Extreme have an "Extreme Analytics" (Purview) deployment guide that covers all the different switches?
And if not it would be very usefull for all extreme users to have a document similar to the Purview/S Series deployment guide, covering the different switch series.
Your comments on this would be welcome
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎12-14-2018 10:29 AM
For XOS = click add in Application Telemetry Sources ?
Select what option you'd need in "Flow Collection Type" and then just click add in Telemetry.
If the switch supports it (= hardware/software) it's available to select and that's it.
XMC will telnet/ssh to the switch and add the required CLI commands.
6 REPLIES 6
‎07-12-2019 06:02 AM
Hi Tomasz, I've found the flow limits on the Realease notes.
Thanks
Thanks
‎07-11-2019 09:01 PM
Hi Antonio,
EXOS devices since 22.4 (all currently on-sale).
VOSS since 7.1.
SLX9140 probably is en route with that.
All above with telemetry (I hate that name, I get flashbacks about some nasty Windows 10 processes).
You might find this useful: https://emc.extremenetworks.com/content/common/releasenotes/extended_firmware_support_8.2.htm
Hope that helps,
Tomasz
VOSS since 7.1.
Hope that helps,
Tomasz
‎06-28-2019 07:18 AM
Hi, is there an update list of all switches model EXOS, VOSS, SLX that support analytics based on the latest releases of software (IPFIX, netflow\N mirror, application telemetry)?
And is there a document for the limits regarding analytics of the different platform?
‎12-27-2018 10:56 AM
For VOSS (VSP) you will need XMC version 8.2
For EXOS you can use 8.1
Regards
Zdeněk Pala
