Syslogs send by Summit-Switch are not displayed in Netsight Syslog
‎01-27-2017 11:30 AM
I configured a X460 with syslog, as stated in https://extremeportal.force.com/ExtrArticleDetail?an=000074214 - everything works fine, in Netsight Alarms and Events, I can see the syslogs of this device.
Exactly the same configuration doesn't work with X440.
In our firewall system I can see, that syslog traffic is send to NetSight, but they won't appear.
Do I need to configure something in Netsight or where is the problem?
‎02-15-2017 11:38 AM
‎01-27-2017 03:27 PM
New messages should be written in the file /var/logs/syslog
If you ssh into EMC you'd do a "tail -f /var/log/syslog" to see new incoming messages.
Do that and and force some syslog message from the X440 and let us know whether you'd see that in the CLI output.
The firewall can see, that syslog traffic is routed to our Netsight, but nothing is shown inside the syslog-file - so neither in the Console/OneView.
This is the switch-configuration:
I connected a device and with the booting, there are logs for netlogin, vlan, etc.
Log Target : syslog; 1.2.3.4:514 (vr VR-Default), local0 Enabled : yes Filter Name : DefaultFilter Match regex : Any Severity : Info (through Critical) Format : PRI Mmm DD HH:MM:SS HOSTNAME TAG: Does anyone has suggestions?
Other switches are working fine with the same config (X440, X460, X670...).
IP connectivity is given, otherwise the firewall wouldn't see passing syslog-packets.
Seems to be an Netsight related issue.
