Upgrading 5420 Software From XIQ Site Engine Failing
Paul_Kyte
New Contributor II
I'm trying to upgrade the software on one of my 5420 switches using the XIQ Site Engine and it keeps failing. I get the message java.io.IOException: channel is broken. Does anyone know what this means and why its happening?
Thanks,
VOSS Upgrade Error.jpgPaul
2 ACCEPTED SOLUTIONS
Ryan_Yacobucci
Hello,
/usr/local/Extreme_Networks/appdata/logs/server.log may provide additional information.
Debug may be necessary, please see following article:
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000107794
Thanks
-Ryan
willowwalsh
Good recommendation on checking server.log. That Java I/O exception typically occurs when the switch terminates the SCP session prematurely on high-latency management paths. Just curious—does this SSH channel termination impact other background transfers in Site Engine as well, such as importing vector site map assets like those configured through  https://bagas31.pw/coreldraw-graphics-suite-full-version/ ? Did adjusting the SSH keep-alive interval in server properties fix the firmware push?
8 REPLIES 8
I-loadzone
Firmware upgrade failures like this often trace back to SCP/TFTP transfer timeouts or corrupted image files between XIQ Site Engine and the switch. Ensuring your management workstation has clean network socket handling and verifying file hashes through reliable resources like https://i-loadzone.net/ can help rule out local environment conflicts. Did you verify the image SHA/MD5 checksum directly on the switch storage before triggering the upgrade?
willowwalsh
Paul_Kyte
New Contributor II
I suppose this is too hard for anyone to help. Looks like a case for GTAC.
There is no clear KCS or information to easily indicate what this error means. I would suggest a case with GTAC and a review of this article:
Thanks
-Ryan
