ā10-31-2023 07:06 AM - edited ā10-31-2023 07:23 AM
We are bombarded with these rejected events. This is working as designed, correct? All of our VOSS switches are set to check reachability every 3 minutes. It seems odd that the check is performed with a rejection, maybe that's standard procedure.
Is Status-Server mode any more efficient (RFC 5997)?
Solved! Go to Solution.
ā11-01-2023 05:33 AM
Hello,
Check out:
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000112893
Also, consider using the reachability checks to reduce load on XIQ-SE if large numbers of healthchecks are being sent:
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000100006
Thanks
-Ryan
ā11-02-2023 05:57 AM
You can use "status-server" on VOSS / Fabric Engine instead of "use-radius" for RADIUS reachability mode.
XIQ-SE supports it.
ā11-02-2023 02:19 AM
ā11-02-2023 05:42 AM
Thank you. I have fixed the permissions on the article.
ā11-01-2023 02:15 PM
The solution I prefer is the one that requires the least resources from both the switches and the radius servers.
regards
WillyHe
