X430 netlogin - shutdown port
Ronald_Dvorak
Honored Contributor
the setup is a X430 with netlogin / MAC-auth via NAC.
I use RFC3580 to dynamical assign the VLAN to the port (as the X430 doesn't support policy/roles).
I'd like to auto shutdown ports if the client doesn't match a NAC rule or matches my last deny rule.
Is there a way to do it or a CLI netlogin command to shutdown the port if a reject is rx from the NAC.
Thanks,
Ron
2 REPLIES 2
Patrick_Koppen
Contributor
Return a 'shutdown'-profile which starts a upmscript (user-auth triggered), which disables the port....
Or a upm script triggered by the reject event....
Be aware X430 needs at least EXOS 16.2.x to support UPM Scripts!
