In XMC, when i try to configure 802.1X and MAC authentication on a Summit X440-24P Switch, I get a message saying "Errors occured configuring authentication"
N.B: The Switch is running EXOS 16.2 and this was for testing purposes (i'm only a beginner)
Please help
# Module devmgr configuration.
configure snmp sysContact "
[email protected], +1 888 257 3000"
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-24
configure vr VR-Default add ports 1-24
configure vlan Default add ports 1-24 untagged
configure vlan Default ipaddress 172.16.16.62 255.255.0.0
# Module fdb configuration.
# Module rtmgr configuration.
configure iproute add default 172.16.16.254
# Module mcmgr configuration.
# Module policy configuration.
configure policy vlanauthorization enable
# Module aaa configuration.
configure radius 1 server 172.16.16.61 1812 client-ip 172.16.16.62 vr VR-Default
configure radius 1 shared-secret encrypted "#$fGdNLHYZCPSyWsYF8v/diOu0RexVVxdlerdTIeEw"
configure radius-accounting 1 server 172.16.16.61 1813 client-ip 172.16.16.62 vr VR-Default
configure radius-accounting 1 shared-secret encrypted "#$eN/Y+19G0A1oGPg56umvdiDngv3ktnNisFAhULo5"
configure radius-accounting 1 timeout 10
enable radius
enable radius mgmt-access
enable radius netlogin
configure radius timeout 15
configure radius mgmt-access timeout 15
configure radius netlogin timeout 15
enable radius-accounting
enable radius-accounting mgmt-access
enable radius-accounting netlogin
configure account admin encrypted "$5$W7aDg7$xN1Xq9M2vWmIjWnW8ArWc7qoCCsVvnvZExa33O9Kis8"
# Module exsshd configuration.
enable ssh2
# Module netLogin configuration.
configure netlogin dynamic-vlan enable
# Module snmpMaster configuration.
configure snmpv3 add user "snmpuser" engine-id 80:00:07:7c:03:00:04:96:97:a2:6c authentication md5 auth-encrypted localized-key 23??5e:23:f0:68:23:b2:23:b6:23:0e:23:b3:51:23:af:23:d8:23:1c:6f:23:d1:23:d3:23:9f privacy privacy-encrypted localized-key 23:86:30:23:b3:23:aa:23:e5:23:be:4b:7d:2b:23:15:23:8c:66:23:c7:65:40:6e
configure snmpv3 add group "SNMP" user "snmpuser" sec-model usm
configure snmpv3 add access "SNMP" sec-model usm sec-level priv read-view "defaultAdminView" write-view "defaultAdminView" notify-view "defaultAdminView"
configure snmpv3 add community "cisco" encrypted name "cisco" user "snmpuser"
disable snmp access snmp-v1v2c
# Module techSupport configuration.
enable tech-support collector
# Module telnetd configuration.
disable telnet
enable web http
configure ssl certificate hash-algorithm sha512
