02-06-2025 11:48 AM
I have an issue, I have Extreme switch managed by site engine and everything works.
I set profile, cli and snmp connection to manage HP switch but i don't understand how can get backup manually and set weekly backup.
I looking for script in github/Extreme and i found it but i don't understand how can run it on XIQ Site Ingine
Solved! Go to Solution.
02-17-2025 11:58 AM
Right click on the switch you want to backup, then Archives->Inventory settings, and check if you are using correct script
Obviously I just give you example. You may check if the script is good for your purpose. Also you may change the script to different one.
Also please go to:
ExtremeScripting/XMC_XIQ-SE/cfg_backup_scripts at master · extremenetworks/ExtremeScripting · GitHub
And browse for already created scripts. You have also a link to document on how to install those scripts.
After you have all correctly defined you may manually backup the switch by using right click, then Archives -> Backup configuration. It will then create on demand backup.
To schedule you need to go to Archives tab, then click button "Create" on the bottom. Go through the wizard and on on step 3 you'd be asked for "Frequency"
02-17-2025 11:58 AM
Also please go to:
02-07-2025 06:08 AM
How to import the script = https://extreme-networks.my.site.com/ExtrArticleDetail?an=000091050&q=What-directory-do-you-put-cust...
How to select the script to be used = https://emc.extremenetworks.com/content/oneview/docs/network/devices/docs/c_ov_at_firmware_mib_confi...
you need to define CLI credentials and method (SSH/Telnet) for your HP switch
Then you start the backup.
If it does not work, you need to enable debug and check what/where is failing.
Good luck
06-06-2025 01:45 AM
hi
How can restore backup from other device?
06-06-2025 07:16 AM
The IP address is part of the backup, so be careful.
You can clone the config, right click on device > Archives > Restore Configuration > Clone > only devices of the same type can be selected:
Good luck
