XMC 8.2 and missing Topology Definitions and Services Definitions nodes in the Global Tree view
Antonio_Opromol
Contributor II
I've installed a new XMC version 8.2.0.89 with an evaluation license and also installed the Fabric Manager VM also version 8.2.0.89.
Now in my View menù I see the Fabric view option and I'm able to see the Fabric Topology, but are missing in the Global Treee View the new node Topology Definitions and Service Definitions necessary for the Provisioning.
Is necessary to add another license respect the XMC evaluation license or is necessary to enable this function somewhere in the XMC configuration?
Thanks in advance.
8 REPLIES 8
Volker_Kull
Contributor
As I know, you have to be part of the beta test community and require a special key to enable this beta feature.
br
Volker
Stephane_Grosj1
Ok, so just to be clear: 8.2.0.89 is a beta release, for all the components, not only Fabric Manager.
Antonio_Opromol
Contributor II
Yes, when I've downloaded the Fabric Manager VM says that is beta release.
Stephane_Grosj1
I don't think Fabric Provisioning is part of the Beta release of 8.2 (that you are using). Are we clear you are using a Beta release?
