ā02-03-2021 04:03 PM
Hy,
I installed Netsight 8.5.4 this week.
All seemed good so far, today I needed to change a NAC rule.
After Adding a new rule, I was not able to view NAC rules in oneview anymore?
Did anyone else already install 8.5.4 and can test this?
I already sent a ticket to our partner.
BR
Solved! Go to Solution.
ā02-05-2021 08:08 AM
Hello,
I did, yesterday I tested with GTAC.
After copying of extisting NAC Config ā2017ā to new config āGTACā we could reproduce the error also in the copied ruleset. So there was an error in that Nac Ruleset.
Today I tried to find out which rule makes problems, so I deleted a couple of rules in the copied āGTACā ruleset. After that the error did not happen again!?
So I made again a copy of extisting NAC Config ā2017ā to new config ātestā, and deleted one already disabled rule ā no error?!
Problem solved - reason unknown
Now I can go on and try to integrate XIQ to our Extreme Control (NAC on Prem)
ā02-03-2021 04:20 PM
Anton,
At first step, I would reboot XMC.
The error seems to be database related.
During the boot of netsight do a tail -f /usr/local/Extreme/netsight/appdata/log/server.log to check at what moment the error does happen. This can give some information on the error.
Iām not sure about the typo of the path.
Mig
ā02-03-2021 04:14 PM
Thank you
So it has something todo with our setup.
ā02-03-2021 04:06 PM
Antox,
I run 8.5.4 and I didnāt experienced this
Mig
