monitor A4 temperature in netsight
Hello How can I monitor the A4-series switch temperature in netsight? Also How can I read the temperature on other SNMP client? A4 firmware 06.81.02.0007 Netsight 4.0.1.34
the device characters in the map do not show the full name due to the character limit. is it possible to edit this?
Hi all, NMS does not show links between devices after being configured, after some time the links disappear, any idea of what may be happening? The version of NMS is 8.1.2.59.
I can access the switch via ssh through the Mgmt port. Fine. But what I need to know is how can I access the switch via SSH through any of the front ports, 1 to 48. And is there a way to create different Virtual Routers for each vlan.
Hello, In NetSight Policy Manager, I would like to create a set of rules to permit a traffic based on a source IP + source port AND a destination IP range (e.g. 192.168.1.10:80 → 192.168.2.0/24) I can't find how. I can either permit an IP source + po...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
