‎10-07-2019 02:35 PM
Can this virtual appliance be configured for snmp? I would like to add our monitoring tools to manage the xMC via SNMP.
Thank you
Thank you
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎10-24-2019 08:31 PM
Generic snmp agent is running on XMC by default (if XMC was installed as VM or from ISO).
It is standard linux SNMPd => just modify the /etc/snmp/snmpd.conf and restart the snmp service by
service snmpd restart
good luck
Regards
Zdeněk Pala
7 REPLIES 7
‎10-09-2019 02:12 PM
This got me to the place where to add snmpv3. Our solarwinds is set for v2 but added the v3 but not getting anywhere yet. I appreciate the info James. Can I use V2c instead of snmpv3? Thank you
‎10-08-2019 12:51 PM
Is ping monitoring the best we can do to see the health?
‎10-08-2019 10:43 AM
Ted,
AFAIK XMC doens't run an SNMP agent = you can't query from another SNMP mgmt.
-Ron
-Ron
