08-19-2019 04:39 PM
02-26-2021 04:07 PM
Hi Markus,
I agree with you. However when you use the “WebView” from the right click menu, you are also using your local browser and have to login in addition. I think the jump link could be really helpful. Maybe something you could place within your group?
Regards
Daniel
02-26-2021 03:48 PM
Hi Dany,
the advantage to use a WEB based terminal is that you WEB client connect to the XMC server. The XMC server connects than to the device. If we just provide a jump link that you client to straight to the device and have to login in addition is not useful too.
Thx
Markus
02-26-2021 11:52 AM
I understand extending the integrated terminal does not make sense. However was it ever considered to provide an option for passing an URL from XMC to an external application like Putty or WinSCP (ssh://)?
Maybe some browser would need an extension due to security restrictions, but still better than the integrated terminal, which I guess nobody uses.
Accessing device CLI on demand is elementary in daily network operation. Always start an external CLI tool and copy/paste IPs from XMC is not very fancy in my opinion.
02-24-2021 06:22 PM
Hi all,
the WEB terminal is nice but is for sure a quick access solution and not cover think a professional CLI tool normally do. We are not engaged to extend the WEB terminal function, because it was not designed for this reason. Adding features is a never ending story. For professional CLI tools please us ones you can host on you computer.
thx
Markus
