ZTP+ with a custom configuration script
RobertD1
Contributor III
Hello,
Tried assigning a TCL script to add a couple of VLANs to an EXOS switch during ZTP+ discovery. It does not get used.
The script is valid as I know I can run it and select a discovered switch to update which works.
I know ZTP+ does not support Load Configuration templates but thought this could be an alternative to send config  during discovery?
Any thoughts appreciated.
Rob
1 ACCEPTED SOLUTION
Make sure the devices are checking out a license from XIQ, otherwise those Site actions will not happen.
Under Devices, you need to see them getting a tick for XIQ Onboarded, and at least a Pilot license.
8 REPLIES 8
I think the key is ensure that XIQ-SE is licensed otherwise some functionality is no longer available. Even my custom TCL script works when now when I Add Device. Therefore it should also work with ZTP+ discovery.
I will try the Workflow too.
But happier now I see things working. Can delete the device and start over, think the only manual step is to enforce the Policy Domain.
Hi Ludovico,
Your Workflow works perfectly. I can now use a template with variables to add config lines to multiple devices and as part of ZTP+ if needed.
Thanks both!
Ryan_Yacobucci
Hello Robert,
You should be able to trigger an automated task based on ZTP+ to run a script with the custom configuration section:
Also, to my knowledge we should be able to push VLANs through port template assignments through the ZTP+ Automated Templates feature.
If you click on the Site --> Site Tab --> Port Templates there's a section for ZTP+ device and port mappings.
Check to see if the ZTP+ Device Defaults is set to always push configuration updates.
At the bottom of the ZTP+ Device Defaults tab is a "Global to IP Site Mapping" to allow you to have different devices automatically be added into specific Sites that can have different automated tasks or port templates/mappings according to the site requirements.
Thanks
-Ryan
Hi Ryan,
Thanks for your reply. Wonder if it is because I am using a GNS3 VM which is not getting recognized as vendor Extreme?
Rob
