‎03-10-2021 08:41 AM
Hello,
I Have an AP121 who was unused for a while, i removed it from a classic hivemanager and i tried to add it to a ExtremeCloud IQ but the ap never connect to. When i try to add it to another classic Hivemanager, i haven’t connection too. I added the hivemanager server manually but the AP still don't connect.
I Have another AP in the network and this AP is connected, so i don’t think about a firewall misconfiguration.
I thought about the certificate update that Extreme Networks have done (last year ? I don’t remember) but i didn’t kept the certificate update process, so i can’t try this.
If anyone have an idea, it will be welcome.
Thanks in advance.
Regards
Adrien
Solved! Go to Solution.
‎03-10-2021 03:54 PM
Thank you for sharing all of that, it looks like everything is checking out and the AP thinks it’s connected. You might have a bad AP here, I’d recommend submitting a case to request an RMA.
‎03-16-2021 11:25 AM
Hello,
I have replaced the AP by a 305C, in the same switch interface, with the same network cable, and it works, it seems the AP121 is out of order.
Thanks for the help
‎03-10-2021 03:58 PM
Thanks for the debugs, I am seeing some missed echo packets here, for example:
debug capwap: [capwap_info]: echo no recevie 2 2
capwap: [capwap_info]: ah_capwap_echo_timer timed out
XIQ and the APs have a call and response check-in system that allows them to confirm that each side of the connection is still responsive; these call and response packets are called echos. There is a specific time window within which an AP would need to respond to an echo to be considered still responsive. If the AP misses a certain number of echos back to back, it is considered disconnected until it responds again. If an AP is still connected to the internet and passing traffic while missing echos, it's likely due to latency on the network; the AP is unable to process the echo request quickly enough due to the amount of traffic it has to process before responding.
It might be helpful to check the backend network to look for anything that could cause that delay in passing traffic that is causing the APs to miss their echo response window.
‎03-10-2021 03:55 PM
And this is the log outpout :
AH-aabcc0#_debug capwap info
debug info turned on (0x4)
AH-aabcc0#_debug capwap basic
debug basic turned on (0x6)
AH-aabcc0#_debug capwap stat
debug stat turned on (0x26)
AH-aabcc0#_debug capwap delay
debug delay turned on (0x100026)
AH-aabcc0#no capwap client enable
AH-aabcc0#capwap client enable
AH-aabcc0#show log buff | include all debug
^-- unknown keyword or invalid input
AH-aabcc0#show log buff | include debug
2021-03-10 15:32:01 debug capwap: [capwap_basic]: CAPWAP: cur_status:Run, cur_event:rcvpkt, timer to fire:30
2021-03-10 15:32:01 debug capwap: [capwap_basic]: capwap set watch dog:150 priority:5 modid:4
2021-03-10 15:32:01 debug capwap: [capwap_info]: RUN ECHO->Leave the send packet phase state
2021-03-10 15:32:01 debug capwap: [capwap_basic]: state: Run--->Run, event: sndpkt--->rcvpkt
2021-03-10 15:32:01 debug capwap: [capwap_info]: set timer type is neibo_timer interval is 30
2021-03-10 15:32:01 debug capwap: [capwap_info]: SENDPKT->Send capwap packet
2021-03-10 15:32:01 debug capwap: [capwap_info]: the totle len is 34, col msg head len is 8, options len is 14
2021-03-10 15:32:01 debug capwap: [capwap_info]: unset timer type is echo_timer interval is 0
2021-03-10 15:32:01 debug capwap: [capwap_info]: RUN ECHO->Enter the send packet phase state: Run event: sndpkt timer: neibo_timer
2021-03-10 15:32:01 debug capwap: [capwap_basic]: current parameters:Run sndpkt neibo_timer
2021-03-10 15:32:01 debug capwap: [capwap_info]: ah_capwap_echo_timer timed out
2021-03-10 15:31:32 debug capwap: [capwap_basic]: CAPWAP: cur_status:Run, cur_event:waitting sndpkt, timer to fire:30
2021-03-10 15:31:32 debug capwap: [capwap_basic]: capwap set watch dog:150 priority:5 modid:4
2021-03-10 15:31:32 debug capwap: [capwap_info]: Leave the wait send phase state
2021-03-10 15:31:32 debug capwap: [capwap_info]: set timer type is echo_timer interval is 30
2021-03-10 15:31:32 debug capwap: [capwap_info]: Enter the wait send phase state: Run event: waitting sndpkt timer: echo_timer
2021-03-10 15:31:32 debug capwap: [capwap_basic]: current parameters:Run waitting sndpkt echo_timer
2021-03-10 15:31:32 debug capwap: [capwap_basic]: capwap set watch dog:60 priority:5 modid:4
2021-03-10 15:31:32 debug capwap: [capwap_info]: RUN CHANGE STATE EVENT->Leave the receive packet phase state
2021-03-10 15:31:32 debug capwap: [capwap_basic]: state: Run--->Run, event: rckchgevntpkt--->waitting sndpkt
2021-03-10 15:31:32 debug capwap: [capwap_info]: unset timer type is neibo_timer interval is 0
2021-03-10 15:31:32 debug capwap: [capwap_info]: RUN CHANGE STATE EVENT->Enter the receive packet phase state: Run event: rckchgevnt pkt timer: none
2021-03-10 15:31:32 debug capwap: [capwap_basic]: current parameters:Run rckchgevntpkt none
2021-03-10 15:31:32 debug capwap: [capwap_delay]: Reconnect to HM, set delay flag to major
2021-03-10 15:31:32 debug capwap: [capwap_info]: Rcv msg type:12
2021-03-10 15:31:32 debug capwap: [capwap_info]: This packet is not a fragment packet
2021-03-10 15:31:32 debug capwap: [capwap_info]: the fragment information number is:00 hdr is:70400000
2021-03-10 15:31:32 debug capwap: [capwap_info]: the CAPWAP transport header len is 16
2021-03-10 15:31:31 debug capwap: [capwap_basic]: CAPWAP: cur_status:Run, cur_event:rckchgevntpkt, timer to fire:15
2021-03-10 15:31:31 debug capwap: [capwap_basic]: capwap set watch dog:135 priority:5 modid:4
2021-03-10 15:31:31 debug capwap: [capwap_info]: RUN CHANGE STATE EVENT->Leave the send packet phase state
2021-03-10 15:31:31 debug capwap: [capwap_basic]: state: Run--->Run, event: sndchgevntpkt--->rckchgevntpkt
2021-03-10 15:31:31 debug capwap: [capwap_info]: set timer type is neibo_timer interval is 15
2021-03-10 15:31:31 debug capwap: [capwap_info]: SENDPKT->Send capwap packet
2021-03-10 15:31:31 debug capwap: [capwap_info]: the totle len is 266, col msg head len is 8, options len is 246
2021-03-10 15:31:31 debug capwap: [capwap_info]: current box switch chip version: 00000000
2021-03-10 15:31:31 debug capwap: [capwap_info]: current box is AP
2021-03-10 15:31:31 debug capwap: [capwap_info]: current PPPoE is disable
2021-03-10 15:31:31 debug capwap: [capwap_info]: current AP is indoor
2021-03-10 15:31:31 debug capwap: [capwap_info]: fill hiveap info: transfer mode:TCP, destinatin port:80, proxy name:, proxy port:0
2021-03-10 15:31:31 debug capwap: [capwap_info]: CHANGE STATE EVENT->Enter the send packet phase state: Run event: sndchgevntpkt tim er: neibo_timer
2021-03-10 15:31:31 debug capwap: [capwap_basic]: current parameters:Run sndchgevntpkt neibo_timer
2021-03-10 15:31:31 debug capwap: [capwap_basic]: capwap set watch dog:60 priority:5 modid:4
2021-03-10 15:31:31 debug capwap: [capwap_info]: JOIN->Leave the receive packet phase state.
2021-03-10 15:31:31 debug capwap: [capwap_info]: capwap handle_bonjour_service service old 0 new 3
2021-03-10 15:31:31 debug capwap: [capwap_basic]: state: Join--->Run, event: rcvpkt--->sndchgevntpkt
2021-03-10 15:31:31 debug capwap: [capwap_info]: unset timer type is wait_timer interval is 0
2021-03-10 15:31:31 debug capwap: [capwap_info]: JOIN->Enter the receive packet phase state: Join event: rcvpkt timer: none
2021-03-10 15:31:31 debug capwap: [capwap_basic]: current parameters:Join rcvpkt none
2021-03-10 15:31:31 debug capwap: [capwap_info]: Rcv msg type:4
2021-03-10 15:31:31 debug capwap: [capwap_info]: This packet is not a fragment packet
2021-03-10 15:31:31 debug capwap: [capwap_info]: the fragment information number is:00 hdr is:70400000
2021-03-10 15:31:31 debug capwap: [capwap_info]: the CAPWAP transport header len is 16
2021-03-10 15:31:31 debug capwap: [capwap_basic]: CAPWAP: cur_status:Join, cur_event:rcvpkt, timer to fire:60
2021-03-10 15:31:31 debug capwap: [capwap_basic]: capwap set watch dog:180 priority:5 modid:4
2021-03-10 15:31:31 debug capwap: [capwap_info]: JOIN->Leave the send packet phase state
2021-03-10 15:31:31 debug capwap: [capwap_basic]: state: Join--->Join, event: sndpkt--->rcvpkt
2021-03-10 15:31:31 debug capwap: [capwap_info]: set timer type is wait_timer interval is 60
2021-03-10 15:31:31 debug capwap: [capwap_info]: the totle len is 321, col msg head len is 8, options len is 301
2021-03-10 15:31:31 debug capwap: [capwap_basic]: get capwap reconnect reason:1006
2021-03-10 15:31:31 debug capwap: [capwap_info]: CAPWAP GET MGT0 IP TYPE FROM SCD IS 2
2021-03-10 15:31:31 debug capwap: [capwap_info]: CAPWAP GET COUNTRY CODE FROM DCD IS 250
2021-03-10 15:31:31 debug capwap: [capwap_info]: CAPWAP GET WTP REGION CODE FROM DCD IS 1
2021-03-10 15:31:31 debug capwap: [capwap_info]: CAPWAP GET WTP GATEWAY FROM DCD IS 10.34.10.254
2021-03-10 15:31:31 debug capwap: [capwap_info]: CAPWAP GET WTP MASK FROM DCD IS 255.255.255.0
2021-03-10 15:31:31 debug capwap: [capwap_info]: Get CLI configuration version:1
2021-03-10 15:31:31 debug capwap: [capwap_info]: CAPWAP GET WTP HW module from SCD is HiveAP121
2021-03-10 15:31:31 debug capwap: [capwap_info]: CAPWAP get box SN from SCD is 1211512XXXXXX
2021-03-10 15:31:31 debug capwap: [capwap_info]: CAPWAP GET WTP MAC FROM DCD IS f09c:e9aa:bcc0
2021-03-10 15:31:31 debug capwap: [capwap_info]: location:(change_me),len:9
2021-03-10 15:31:31 debug capwap: [capwap_info]: JOIN->Enter the send packet phase state: Join event: sndpkt timer: wait_timer
2021-03-10 15:31:31 debug capwap: [capwap_basic]: current parameters:Join sndpkt wait_timer
2021-03-10 15:31:31 debug capwap: [capwap_info]: capwap handle_bonjour_service service old 0 new 2
2021-03-10 15:31:31 debug capwap: [capwap_info]: HTTP proxy done its first time connecting to HM
2021-03-10 15:31:31 debug capwap: [capwap_basic]: state: DTLS setup--->Join, event: DTLS connect--->sndpkt
2021-03-10 15:31:30 debug capwap: [capwap_basic]: CAPWAP: cur_status:DTLS setup, cur_event:DTLS connect, timer to fire:60
2021-03-10 15:31:30 debug capwap: [capwap_basic]: capwap set watch dog:180 priority:5 modid:4
2021-03-10 15:31:30 debug capwap: [capwap_info]: DTLS SETUP->Leave the DTLS setup State.
2021-03-10 15:31:30 debug capwap: [capwap_info]: set timer type is DTLS_handshake_timer interval is 60
2021-03-10 15:31:30 debug capwap: [capwap_info]: unset timer type is discovery_timer interval is 0
2021-03-10 15:31:30 debug capwap: [capwap_basic]: UNICAST: IP = 52.214.249.84,Port = 80
2021-03-10 15:31:30 debug capwap: [capwap_info]: DTLS SETUP->Enter the DTLS setup State.
2021-03-10 15:31:30 debug capwap: [capwap_basic]: current parameters:DTLS setup DTLS connect DTLS_handshake_timer
2021-03-10 15:31:30 debug capwap: [capwap_info]: ah_capwap_discovey_timer timed out
2021-03-10 15:31:26 debug capwap: [capwap_basic]: CAPWAP: cur_status:DTLS setup, cur_event:DTLS connect, timer to fire:5
2021-03-10 15:31:26 debug capwap: [capwap_basic]: capwap set watch dog:125 priority:5 modid:4
2021-03-10 15:31:26 debug capwap: [capwap_info]: DISCOVERY->Leave the receive packet phase state.
2021-03-10 15:31:26 debug capwap: [capwap_info]: capwap handle_bonjour_service service old 0 new 2
2021-03-10 15:31:26 debug capwap: [capwap_info]: HTTP proxy done its first time connecting to HM
2021-03-10 15:31:26 debug capwap: [capwap_basic]: state: Discovery--->DTLS setup, event: rcvpkt--->DTLS connect
2021-03-10 15:31:26 debug capwap: [capwap_info]: set timer type is discovery_timer interval is 5
2021-03-10 15:31:26 debug capwap: [capwap_info]: unset timer type is discovery_timer interval is 0
2021-03-10 15:31:26 debug capwap: [capwap_info]: DISCOVERY->Enter the receive packet phase state: Discovery event: rcvpkt timer: dis covery_timer
2021-03-10 15:31:26 debug capwap: [capwap_basic]: current parameters:Discovery rcvpkt discovery_timer
2021-03-10 15:31:26 debug capwap: 30ba70f4 06 c2 32 b9 cb 36 ..2..6
2021-03-10 15:31:26 debug capwap: [capwap_info]: Get CAPWAP AC mac is:
2021-03-10 15:31:26 debug capwap: [capwap_info]: the type is 6005, the len is 6 the value is :
2021-03-10 15:31:26 debug capwap: [capwap_info]: Rcv msg type:2
2021-03-10 15:31:26 debug capwap: [capwap_info]: This packet is not a fragment packet
2021-03-10 15:31:26 debug capwap: [capwap_info]: the fragment information number is:00 hdr is:70400000
2021-03-10 15:31:26 debug capwap: [capwap_info]: the CAPWAP transport header len is 16
2021-03-10 15:31:25 debug capwap: [capwap_basic]: CAPWAP: cur_status:Discovery, cur_event:rcvpkt, timer to fire:5
2021-03-10 15:31:25 debug capwap: [capwap_basic]: capwap set watch dog:125 priority:5 modid:4
2021-03-10 15:31:25 debug capwap: [capwap_info]: DISCOVERY->Leave the send packet phase state
2021-03-10 15:31:25 debug capwap: [capwap_basic]: state: Discovery--->Discovery, event: sndpkt--->rcvpkt
2021-03-10 15:31:25 debug capwap: [capwap_info]: set timer type is discovery_timer interval is 5
2021-03-10 15:31:25 debug capwap: [capwap_info]: SENDPKT->Send capwap packet
2021-03-10 15:31:25 debug capwap: [capwap_info]: the totle len is 215, col msg head len is 8, options len is 195
2021-03-10 15:31:25 debug capwap: [capwap_info]: CAPWAP GET WTP MAC FROM DCD IS f09c:e9aa:bcc0
2021-03-10 15:31:25 debug capwap: [capwap_info]: Get CLI configuration version:1
2021-03-10 15:31:25 debug capwap: [capwap_info]: CAPWAP GET WTP HW module from SCD is HiveAP121
2021-03-10 15:31:25 debug capwap: [capwap_info]: CAPWAP get box SN from SCD is 1211512XXXXXX
2021-03-10 15:31:25 debug capwap: [capwap_info]: unset timer type is maxdis_timer interval is 0
2021-03-10 15:31:25 debug capwap: [capwap_info]: DISCOVERY->Enter the send packet phase state: Discovery event: sndpkt timer: discov ery_timer
2021-03-10 15:31:25 debug capwap: [capwap_basic]: current parameters:Discovery sndpkt discovery_timer
2021-03-10 15:31:25 debug capwap: [capwap_info]: ah_capwap_maxdisco_timer timed out
2021-03-10 15:31:25 debug capwap: [capwap_basic]: state: Discovery--->Discovery, event: waitting sndpkt--->sndpkt
2021-03-10 15:31:15 debug capwap: [capwap_basic]: CAPWAP: cur_status:Discovery, cur_event:waitting sndpkt, timer to fire:10
2021-03-10 15:31:15 debug capwap: [capwap_basic]: capwap set watch dog:130 priority:5 modid:4
2021-03-10 15:31:15 debug capwap: [capwap_info]: Leave the wait send phase state
2021-03-10 15:31:15 debug capwap: [capwap_info]: set timer type is maxdis_timer interval is 10
2021-03-10 15:31:15 debug capwap: [capwap_info]: Enter the wait send phase state: Discovery event: waitting sndpkt timer: maxdis_tim er
2021-03-10 15:31:15 debug capwap: [capwap_basic]: current parameters:Discovery waitting sndpkt maxdis_timer
2021-03-10 15:31:15 debug capwap: [capwap_info]: ah_capwap_idle_timer timed out
2021-03-10 15:31:11 debug capwap: [capwap_basic]: CAPWAP: cur_status:Idle, cur_event:none, timer to fire:5
2021-03-10 15:31:11 debug capwap: [capwap_basic]: capwap set watch dog:121 priority:5 modid:4
2021-03-10 15:31:11 debug capwap: [capwap_info]: IDLE->Leave the Idle State.
2021-03-10 15:31:11 debug capwap: [capwap_info]: set timer type is idle_timer interval is 5
2021-03-10 15:31:09 debug capwap: [capwap_info]: register port :80
2021-03-10 15:31:08 debug capwap: [capwap_info]: unregister port:80, proxy port:12222
2021-03-10 15:31:08 debug capwap: [capwap_info]: Clean frag buffer..
2021-03-10 15:31:08 debug capwap: [capwap_basic]: UNICAST: IP = 52.214.249.84,Port = 80
2021-03-10 15:31:08 debug capwap: [capwap_info]: IDLE->Enter the Idle State.
2021-03-10 15:31:08 debug capwap: [capwap_basic]: current parameters:Idle none idle_timer
2021-03-10 15:31:08 debug capwap: [capwap_basic]: capwap set watch dog:60 priority:5 modid:4
2021-03-10 15:31:08 debug capwap: [capwap_info]: START->Leave the Get HM IP State.
2021-03-10 15:31:08 debug capwap: [capwap_info]: capwap handle_bonjour_service service old 0 new 2
2021-03-10 15:31:08 debug capwap: [capwap_info]: HTTP proxy done its first time connecting to HM
2021-03-10 15:31:08 debug capwap: [capwap_basic]: state: Waitting for HiveManager IP--->Idle, event: none--->none
2021-03-10 15:31:08 debug capwap: [capwap_info]: register port :80
2021-03-10 15:31:08 debug capwap: [capwap_info]: START->Enter the Get HM IP State.
2021-03-10 15:31:08 debug capwap: [capwap_basic]: current parameters:Waitting for HiveManager IP none none
2021-03-10 15:31:08 debug capwap: [capwap_info]: START->Leave the Get Host IP State.
2021-03-10 15:31:08 debug capwap: [capwap_basic]: state: Waitting for HiveAP IP--->Waitting for HiveManager IP, event: none--->none
2021-03-10 15:31:08 debug capwap: [capwap_info]: IP = 0.0.0.0,Port = 0
2021-03-10 15:31:08 debug capwap: [capwap_info]: device ip is 10.34.10.3
2021-03-10 15:31:08 debug capwap: [capwap_info]: START->Enter the Get Host IP State.
2021-03-10 15:31:08 debug capwap: [capwap_basic]: current parameters:Waitting for HiveAP IP none none
2021-03-10 15:31:08 debug capwap: [capwap_info]: START->Leave the Start State.
2021-03-10 15:31:08 debug capwap: [capwap_basic]: state: Start--->Waitting for HiveAP IP, event: waitting for cli--->none
2021-03-10 15:30:39 debug capwap: [capwap_info]: START->Enter the Start State.
2021-03-10 15:30:39 debug capwap: [capwap_basic]: current parameters:Start waitting for cli none
2021-03-10 15:30:39 debug capwap: [capwap_info]: timer ah_capwap_dtls_disconn_timer timed out
2021-03-10 15:30:34 debug capwap: [capwap_basic]: CAPWAP: cur_status:DTLS cut, cur_event:DTLS abort, timer to fire:5
2021-03-10 15:30:34 debug capwap: [capwap_basic]: capwap set watch dog:125 priority:5 modid:4
2021-03-10 15:30:34 debug capwap: [capwap_info]: DTLS ABORT->Leave the DTLS abort State.
2021-03-10 15:30:34 debug capwap: [capwap_info]: set timer type is DTLS_delete_timer interval is 5
2021-03-10 15:30:34 debug capwap: [capwap_info]: DTLS ABORT->Enter the DTLS abort State.
2021-03-10 15:30:34 debug capwap: [capwap_basic]: current parameters:DTLS cut DTLS abort DTLS_delete_timer
2021-03-10 15:30:34 debug capwap: [capwap_info]: ah_capwap_neigbor_timer timed out
2021-03-10 15:30:34 debug capwap: [capwap_info]: echo no recevie 2 2
The AP stay unmanaged
