‎03-10-2021 08:41 AM
Hello,
I Have an AP121 who was unused for a while, i removed it from a classic hivemanager and i tried to add it to a ExtremeCloud IQ but the ap never connect to. When i try to add it to another classic Hivemanager, i haven’t connection too. I added the hivemanager server manually but the AP still don't connect.
I Have another AP in the network and this AP is connected, so i don’t think about a firewall misconfiguration.
I thought about the certificate update that Extreme Networks have done (last year ? I don’t remember) but i didn’t kept the certificate update process, so i can’t try this.
If anyone have an idea, it will be welcome.
Thanks in advance.
Regards
Adrien
Solved! Go to Solution.
‎03-10-2021 03:54 PM
Thank you for sharing all of that, it looks like everything is checking out and the AP thinks it’s connected. You might have a bad AP here, I’d recommend submitting a case to request an RMA.
‎03-10-2021 11:41 AM
Do a “show version” on the ap
‎03-10-2021 11:31 AM
It Works too
CAPWAP ping parameters:
Destination server: 52.214.249.84 (52.214.249.84)
Destination port: 12222
Count: 5
Timeout: 5 seconds
CAPWAP ping result:
82 bytes from 52.214.249.84 udp port 12222: seq=1 time=85.848 ms
82 bytes from 52.214.249.84 udp port 12222: seq=2 time=84.781 ms
82 bytes from 52.214.249.84 udp port 12222: seq=3 time=85.765 ms
82 bytes from 52.214.249.84 udp port 12222: seq=4 time=85.265 ms
82 bytes from 52.214.249.84 udp port 12222: seq=5 time=85.272 ms
------- 52.214.249.84 CAPWAP ping statistics -------
5 packets transmitted, 5 received, 0.00% packet loss, time 5431.446ms
rtt min/avg/max = 84.781/85.386/85.848 ms
AH-aabcc0#capwap ping hm-emea-203.aerohive.com
Destination server: hm-emea-203.aerohive.com (52.214.249.84)
Count: 5
Timeout: 5 seconds
CAPWAP ping result:
82 bytes from 52.214.249.84 udp port 12222: seq=1 time=84.979 ms
82 bytes from 52.214.249.84 udp port 12222: seq=2 time=85.568 ms
82 bytes from 52.214.249.84 udp port 12222: seq=3 time=85.984 ms
82 bytes from 52.214.249.84 udp port 12222: seq=4 time=84.565 ms
82 bytes from 52.214.249.84 udp port 12222: seq=5 time=85.776 ms
------- hm-emea-203.aerohive.com CAPWAP ping statistics -------
5 packets transmitted, 5 received, 0.00% packet loss, time 5586.228ms
rtt min/avg/max = 84.565/85.374/85.984 ms
AH-aabcc0#ping google.fr
PING google.fr (216.58.213.131) 56(84) bytes of data.
64 bytes from 216.58.213.131: icmp_seq=1 ttl=110 time=71.9 ms
64 bytes from 216.58.213.131: icmp_seq=2 ttl=110 time=72.5 ms
64 bytes from 216.58.213.131: icmp_seq=3 ttl=110 time=71.6 ms
64 bytes from 216.58.213.131: icmp_seq=4 ttl=110 time=72.5 ms
64 bytes from 216.58.213.131: icmp_seq=5 ttl=110 time=71.5 ms
--- google.fr ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4004ms
rtt min/avg/max/mdev = 71.587/72.056/72.589/0.476 ms
AH-aabcc0#ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=110 time=72.2 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=110 time=71.4 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=110 time=72.0 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=110 time=71.2 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=110 time=71.7 ms
--- 8.8.8.8 ping statistics ---
rtt min/avg/max/mdev = 71.248/71.749/72.281/0.497 ms
‎03-10-2021 11:24 AM
Try to capwap ping your server from the ap’s
capwap ping 52.214.249.84
‎03-10-2021 11:13 AM
Yes, obviously except the AP IP, it’s the same information (i’ve set the hivemanager IP manually in replacement of the URL for saving connection time)
CAPWAP client: Enabled
CAPWAP transport mode: UDP
RUN state: Connected securely to the CAPWAP server
CAPWAP client IP: 10.34.10.1
CAPWAP server IP: 52.214.249.84
HiveManager Primary Name:hm-emea-203.aerohive.com
HiveManager Backup Name:
‎03-10-2021 10:29 AM
Compare this entry,
CAPWAP client IP: 10.34.10.3
HiveManager Primary Name:52.214.249.84
CAPWAP Default Server Name: redirector.aerohive.com
with the Device which is actually working in the XIQ. They should be the same
