04-18-2023 11:48 PM - edited 04-18-2023 11:49 PM
We have migrated from Meraki to Extreme IQ for our wireless solution. In Meraki, there is the ability to disable the LED on an AP. Where is this feature in XIQ as I can't find it?
There is an article that signposts to flashing a LED, but not how to disable the LED. https://extremeportal.force.com/ExtrArticleDetail?an=000110478
04-19-2023 05:58 AM
Hello,
From you network policy, additional settings, Management Options,
Cheers,
Christophe
04-19-2023 05:47 AM - edited 04-19-2023 05:48 AM
Hi ascoyne,
I previously did it through the templates, for the multiple APs in the theatres. Reference the screenshot below. While checking this just now, it seems a cloud update disabled it at some point, so I'll have to test it again and look into Christoph's response. I generally need them to align with templates, though, so my initial assumption is that the solution wouldn't suffice.
04-19-2023 05:39 AM - edited 04-19-2023 05:48 AM
Hello ascoyne,
In the LED Color field you have the option to turn it off:
You can also try the following instructions: https://extremeportal.force.com/ExtrArticleDetail?an=000080178
I hope this helps,
