Interface shows wrong value for transmit Power
DeVoID
Valued Contributor
hi,
I've been going through all of our AP650(ah) AP's and lowering the transmission power on with wifi0 and wifi1 interfaces.
I have set a the power to 10 on both interfaces for 10 AP's in a two floor building.  While the XIQ shows that 8 of the 10 AP's are showing the correct Transmission power, i have 2 AP's that are showing as Auto on wifi0, but the correct 10db on wifi1....
If i go into configuration at the device level, wifi0 is set to manual and 10db.
Which should i believe the XIQ interface, or what the device config shows?
Any ideas why this is going on?
thanks,
J.
25 REPLIES 25
SamPirok
Hey, I would believe the CLI over the Web GUI. It's likely that the GUI is just lagging, or if it doesn't catch up after about a day then it's likely a GUI bug. The only troubleshooting step I'd recommend before trying a support ticket is to fully update the APs; a complete configuration update with a reboot and moving to the latest firmware version if you aren't already there.
