05-05-2020 10:16 AM
Hey!
I recently opened a new support case at extreme networks because of a few interference problems and client connection issues in our network. Finally i was told that there should be a new firmware upgrade for the Extreme Cloud IQ On Premises and apart from that for our networks.
So in our network we are running the following software and versions:
ExtremeCloud IQ Virtual Appliance
Build Id: 2020-03-11-20.23.43
Build Version: 20.1.3.2-NGVA
AP Model
AP 130
IQ Engine 10.0r8
So obviously i am not able to find new firmware upgrade software packages for the mentioned software above. I am even not able too find anything here abount the AP 130 .
So actually since the migration from Hivecommunity to extreme portal, the transparency went worse.
Where can i find the respective new firmware upgrades for the AP 130 IQ Engine and especially for the Extreme Cloud IQ On Premises Software?
Solved! Go to Solution.
05-05-2020 10:32 AM
10.0.8.8 would go against the traditional AP OS naming convention, the next version should be 10.0r9 by normal naming standards. Of course they may have changed this, but I’d be surprised!
Downloads can be found here: https://extremeportal.force.com/ExtrSupportHome but as I say the versions that you have are the newest.
05-06-2020 11:15 AM
Navigate to “Support” → “Support Portal” → “Downloads” → “Downloads Home” and search for example for “AP130”.
05-05-2020 10:40 AM
Yeah i also was confused of the naming convention and i also agree with you. I guess it should be something like 10.0r9 as you said.
This is the message from the support case, you see what i mean:
GTAC
4/30/2020 1:20 AM - Self Service User
Thank you for the information.
We just find out that this is a known issue and we’re going to release a bug fix, ETA for the fix somewhere around 5 May 2020.
Will inform you once the fix release in portal for download.
Besides, will transfer this case to CET time zone support. Thank you for your patient.
Best Regards
SY Choo
So it could also be, that this update will arrive within the next days but what i mean is, i am not able to find the download area of the AP 130 (see the following screenshot)
05-05-2020 10:32 AM
05-05-2020 10:28 AM
Hey,
yeah but i was told that there should be a newer version, something like 10.0.8.8.,
so even if they aren’t visibile or available yet, in which download are i could find those download packages?
05-05-2020 10:25 AM
Hello,
Both your APs and On-premise version are the latest versions currently.
