Extreme Control Enfrocement
Ian_Broadway
Contributor
Hi All,
Added a few new switches to Extreme Control.
I enforce after adding and then enforce after the auth/radius tool.
I unable to do the latter at the moment because the first enforce is still “Audit in Progress”
Doesnt give me any info on what the delay is, has to be +20 minutes as of writing this post like this.
There's no cancel option I can see to stop the audit either?
I’ve also restarted both NAC appliances (site only in optional auth/listening mode) but no difference.
Do I need to restart XMC to resolve potentially?
Cant find any info in knowledgebase for it either.
Any thoughts would be helpful
Thanks
Ian
1 ACCEPTED SOLUTION
StephanH
Valued Contributor III
Hello Ian,
I do not know of any KB entry. But the easiest way is certainly the one you already mentioned. Restart the XMC service. On the CLI with "service nsserver restart".
Regards Stephan
2 REPLIES 2
Ian_Broadway
Contributor
thanks for the reply, its a windows box but i’ll restart and report.
StephanH
Hello Ian,
Regards Stephan
