‎03-16-2021 08:16 AM
Copper port not getting up between 2 extreme 220 series switches. The copper cable length is around 90 meters. But when we connect both these switches back to back (means at same location) then the port gets up. We tested copper cable via LAN tester it is fine. Please let me know if this is due to large distance between 2 switches or any other reason.
Solved! Go to Solution.
‎03-18-2021 07:38 AM
‎03-16-2021 05:17 PM
Technically the distance limit for copper cables should be 100 meters, but we are very close to the limit. What model GBIC are you using? You might want a long range model (LR) for that distance.
