Extreme 220- Setup management access on system IP rather than OOB mgmt port
Tucker_Bidleman
New Contributor II
I have several Extreme 220s going out to a customer. This is a small deployment and rather than using the out of band mgmt port, I am trying to setup management access via the system IP. All internal routing is handled on a Watchguard firewall and I currently have all VLANs routing properly. I have set the mgmt VLAN accordingly using the network mgmt_vlan 5 command and assigned the system IP accordingly on that subnet. My other trunk ports utilizing VLAN 5 as the access VLAN pass connectivity through just fine. Any assistance would be greatly appreciated. This is our first Extreme deployment, so we are still working to get our feet wet with the platform.
6 REPLIES 6
Tucker_Bidleman
New Contributor II
Hey John, I used the steps detailed above with no luck. Does routing have to be enabled for this to work?
