ERS 4950 Power supply OperState OID
Hatem
New Contributor III
Hello,
I'm searching for OID that can give me information on power supply for ERS 4950 with this version : 7.8.1.055.
I tried all MIBs that I downloaded from Extreme Networks portal, but I haven't find the right one. Thanks for your help.
6 REPLIES 6
EF
Contributor III
rcChasPowerSupplyOperStatus OBJECT-TYPE
SYNTAX         INTEGER {
          unknown(1),
          empty(2),
          up(3),
                down(4)
MAX-ACCESS     read-only
STATUS         current
DESCRIPTION   "Actual status of the power supply:
              - unknown(1) - status can not be determined.
              - empty(2) - power supply not installed.
              - up(3) - present and supplying power.
              - down(4) - present, but failure indicated."
::= { rcChasPowerSupplyEntry 2 }
EF
Contributor III
Maybe RAPID-CITY.MIB, Name: rc chas power supply oper status, oid: 1.3.6.1.4.1.2272.1.4.8.1.1.2, Description : Actual status of the power supply: - unknown(1) - status can not be determined. - empty(2) - power supply not installed. - up(3) - present and supplying power. - down(4) - present, but failure indicated.
Selena
I attempted to monitor the ERS 4950 Power Supply OperState OID, but I'm encountering inconsistent or no data in SNMP polls. It seems like the OID might not be returning valid status values or might not be supported on my current firmware version. Has anyone successfully used this specific OID on the ERS 4950? HP Instant Ink  Could it be that a different OID is required for newer firmware revisions?
GavinB
I agree with this, why do the mib files not contain OID's that can find this kind retrieve this info, I have the same problem with the CPU, none of the MIBs given work ?
