06-11-2021 11:06 AM
I wanted to get some guidance on replacing a base unit in a stack please.
I have read through: https://extremeportal.force.com/ExtrArticleDetail?an=000086890 but am a little unsure.
Can I set a working switch within the stack to the base (flick switch and reboot), removing the base switch on the faulty unit as well.
Then install the new replacement unit, reboot.
Set new unit to base, and change other unit back to stack member (flick base switch) and reboot.
I have already set the new replacement unit to the same firmware and software version as the existing stack, and backed up the binary and ascii config.
Thanks.
Solved! Go to Solution.
06-13-2021 12:12 AM
06-11-2021 04:42 PM
Correct, i need to replace a base unit.
06-11-2021 04:11 PM
Hi
From the above scenario, I am thinking you are trying to replace the base unit of the stack. Am I correct?
DILRAJ
