Automatic config backup / L2Edge license
Alexandr_P
Valued Contributor
Hello, colleagues!
Is there some ideas how can I automatically backup configurations from L2 switches with L2 Edge license.
UPM work from Edge license.
Thank you!
8 REPLIES 8
_up__bb_
New Contributor III
Hi Frank I'm intrested too,
I have tryed with rancid but without satisfaction woth exos switches.
Thanks
Roberto
Disclaimer/CMA time: I know it's neither elegant nor pretty, but I modified the ?login and ?rancid scripts so they work for what I need them to do. I also added a line to "rancid-fe" to support the vendor "extreme" tag (and call the proper scripts)
They're all in the attached .tgz file.
It's quite possible that there is better/proper support built in to rancid or available through the forums.
And I don't know how to attach a TGZ file - I'll try to email it to you.
dflouret
Frank,
can you share here the changes you made to scripts in case others are interested in exploring the tool?
Thanks!
PARTHIBAN_CHINN
Contributor
yes this should be possible.
Also from 15.6 exos supports python scripts.
Please refer page 377 in 15.6 concepts guide.
