CONFIGURING TACACS+ SOLUTION ON EXTREME SWITCH
ola
Dears,
i need a solution to configure an authentication server on an extreme switch BD-8806
Here is my script , it not working and i keep getting authentication denied when i tried login in to the switch
TACACS+ CONFIGURATION
# This is the key that clients have to use to access Tacacs+
key = test123
###THIS WAS MEANT TO WORK FOR EXTREME NODE###
user = stef {
member = admingroup
login = cleartext extreme
service = Extreme-XMC-Auth {
local-user-name = remote-su
SWITCH CONFIGURATION
configure tacacs primary server 10.17.21.196 49 client-ip 10.10.8.5 vr VR-Default
configure tacacs primary shared-secret encrypted "test123"
enable tacacs
enable tacacs-authorization
Above are my script , i need a solution that works
1 ACCEPTED SOLUTION
CThompsonEXOS
When you use the "encrypted" keyword it is expecting an encrypted string that it needs to decrypt.
Can you change it to this?
configure tacacs primary shared-secret test123​
EXOS always encrypts credentials so it will show in the configuration like this:
configure tacacs primary shared-secret encrypted "#$bb+3R99U8zhsAGv7ZykeGacBRVU9nA=="​
Thanks,
Chris Thompson
2 REPLIES 2
CThompsonEXOS
Thanks,
Chris Thompson
Thank you Chris,
Issue resolved .
