EPS-500 External Power Supply Unit (Model 10911) compatibility with the Summit X440 48t and 48P.
Raghurajan__San
Hi, Can anyone tell me if the EPS-500 External Power Supply Unit (Model 10911) is compatible with the Summit X440 48t and 48P. The pins look like they will connect but I just wanted to be sure.
6 REPLIES 6
Bill_Stritzinge
I do not believe that the EPS-500 is compatible with the X440, there is firmware that it needs to work correctly and the 500 is an old unit with a fixed power supply. The one compatible is the EPS-C2.
Ronald_Dvorak
Honored Contributor
Hi, doesn't look like if you check the datasheet...
http://learn.extremenetworks.com/rs/extreme/images/Summit-X440x-DS.pdf
-Ron
