05-18-2021 01:00 PM
Hello,
today I played around with the built-in packet capture of EXOS ( How To: How to perform a local packet capture on an EXOS switch | Extreme Portal (force.com) )
I’m able to capture packets and open the pcap file with wireshark, but I only see the following packets:
Wondering if I’m doing something wrong or if the feature is something else than I’m thinking. Any hints?
Best regards
Stefan
Solved! Go to Solution.
05-18-2021 03:54 PM
You can use the editcap tool to remove the first 52 bytes. Mine looked something like below from Powershell:
PS C:\Program Files\Wireshark> .\editcap.exe -C 52 editcap.pcap newpcap.pcap
syntax below:
PS C:\Program Files\Wireshark> .\editcap.exe -C 52 <original pcap filename> <new pcap filename>Below is more on editcap:
https://www.wireshark.org/docs/man-pages/editcap.html
Before:
After:
Thanks,
Chris Thompson
2 weeks ago - last edited 2 weeks ago
This is an interesting question because the built-in packet capture feature can be a bit confusing at first. If you're only seeing those packets in Wireshark, it may be related to the capture point, applied filters, or hardware offloading rather than the traffic itself. Checking the interface configuration and testing with a known traffic Gomovies flow could help narrow down the cause. I'd be interested to know what the final solution was, as it could be useful for anyone troubleshooting EXOS packet captures in the future.
05-18-2021 01:17 PM
Hi Chris,
thanks for your quick reply! I’m on 30.7.1.1-patch1-86. Switch is an X460-G2. I’m just doing some testing of this feature and don’t want to capture any specific traffic for now. But we might need this feature in the near future. (Troubleshooting at a customers site)
Best regards
Stefan
05-18-2021 01:05 PM
Are you on 30.x or newer? IIRC some bytes need to be stripped to be read properly if so.
Generally it’s used for troubleshooting and debugging:
Be Aware!
Debug commands are primarily meant for trouble shooting purposes and are NOT part of any EXOS validation tests (regression).
The usage of any debug command can result in unexpected side-effects (like memory depletion, high CPU, process failures).Is there a certain type of traffic you are trying to capture?
Thanks,
Chris Thompson
