Firmware Update X440-G2-12p failure
Carsten_Volmer
New Contributor II
Hi, there!
I have got a problem with two X440-G2-12p. They are working both with firmware 30.2.2.17 and i can’t take them to a higher firmware. I’ve tried 30.4.1.2, 30.5.1.15v and 30.6.1.11-patch1-11. Both switches are downloading the new firmware and they are beginning to install it, but then i get Error like these:
Error: Failed to install image - Unable to create persistent partition /dev/mmcblk0p10  Rescue using EXOS 30.2 or later
Failed to install image - /dev/mmcblk0p9 (data) partition not found on /dev/mmcblk0.  Rescue using EXOS 30.2 or later
On the other hand i’ve some other switches of the same type and they get the latest firmware without any problems.
What can i do to fix these both switches?
Thank you for your statements!
Carsten
7 REPLIES 7
Carsten_Volmer
New Contributor II
It didn’t work with the 30.2.2.8 😞
Any other idea?
Carsten_Volmer
New Contributor II
Hi, Nikolay!
Thank you for your reply. I#ve tried it befor withe the version 30.2.2.17. I installed in in both partitions and rebootet from each of it. But the error left. Now i will try it with version 30.2.2.8.
Two of these switches are running withe the solution with 30.2.2.17 as e step betwenn, but a third one is not running with it. I will see, if it will works with 30.2.2.8. It is really frustrating.
Best regards
Carsten
Necheporenko__N
Hi Carsten,
Please check the following article for a solution.
https://gtacknowledge.extremenetworks.com/articles/Solution/000045944
Best Regards,
Nikolay
