10-12-2020 04:54 AM
cisco config --
track 14 ip sla 14 reachability
track 20 ip sla 20 reachability
track 30 ip sla 30 reachability
ip sla 14
icmp-echo 172.16.98.5 source-ip 172.16.98.6
frequency 20
ip sla schedule 14 life forever start-time now
ip sla 20
icmp-echo 10.6.158.29 source-ip 10.6.158.30
frequency 20
ip sla schedule 20 life forever start-time now
ip sla 30
icmp-echo 10.20.30.101 source-ip 10.20.30.102
frequency 30
ip sla schedule 30 life forever start-time now
route-map PGCIL permit 10
match ip address 199
set ip next-hop verify-availability 172.16.98.5 1 track 14
set ip next-hop verify-availability 10.6.158.29 5 track 20
set ip next-hop verify-availability 10.20.30.101 10 track 30
route-map TCL permit 10
match ip address 188
set ip next-hop verify-availability 10.6.158.29 1 track 20
ip route 172.16.200.222 255.255.255.255 172.16.98.5 track 14
ip route 172.16.202.52 255.255.255.255 172.16.98.5 track 14
ip route 172.16.202.47 255.255.255.255 172.16.98.5 track 14
ip route 0.0.0.0 0.0.0.0 172.16.98.5 40 track 14
ip route 172.16.108.71 255.255.255.255 10.6.158.29 track 20
ip route 172.16.208.68 255.255.255.255 10.6.158.29 track 20
ip route 172.16.207.53 255.255.255.255 10.6.158.29 track 20
ip route 172.16.108.72 255.255.255.255 10.6.158.29 track 20
Solved! Go to Solution.
10-12-2020 11:02 AM
Hello,
Flow-Redirect is the keyword. https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-flow-redirect
Best regards
Stefan
06-04-2021 10:38 PM
Instead of literal line-by-line translation, it might be easier to think on the goal and adapt these steps:
- Create a .pol file on your laptop and deliver to the switch (could be done through switch web UI with Apps > file browser). It will consist of entries for each set of criteria and next-hop group ie. flow redirect name (like route maps but different naming, isn’t it?).
Entry redirect {
If match all {
source-address 192.0.2.0/24;
} then {
permit;
redirect-name GTAC_redirect;
Just adjust address there and redirect-name to what you’ll create in the next step.
- Create a flow-redirect, a set of hops (like in a route map) under a single name:
create flow-redirect GTAC_redirect
configure flow-redirect GTAC_redirect add nexthop 172.16.98.5 priority 100
configure flow-redirect GTAC_redirect add nexthop 10.6.158.29 priority 90
configure flow-redirect GTAC_redirect add nexthop 10.20.30.101 priority 80
- You can configure a next-hop checks, like that ip sla reachability I believe…
configure flow-redirect GTAC_redirect nexthop 172.16.98.5 ping health-check interval 20 miss 2
- Apply the ACL (policy file) to an interface or VLAN or entire switch:
configure access-list /name/ ports 1 ingress
configure access-list /name/ vlan “test” ingress
configure access-list /name/ any
If it’s still a problem, please let us know what actually is not working for you, what kind of error message etc.
Hope that helps,
Tomasz
05-25-2021 08:29 AM
Can anyone help me to convert above cisco command to extreme commands? I followed link shared by Stefan but unable to execute working config.
10-12-2020 11:02 AM
Hello,
Best regards
Stefan
