‎04-21-2020 05:53 AM
I HAVE A PROBLEM WITH CONFIGURING acl TO THE PORT. I have summit X440G2-48p-10G4 separately and also have a stack of 5 slots. On the switch, the setting is applied, but not on the stack, says a syntax error, but the code is the same everywhere. And when typing the "check policy" command, it answers Policy file check successful. What can be wrong ? The firmware is the same there and there)
‎04-22-2020 11:42 AM
Hello Alexey,
Check if your stack has enough hardware resources to install this ACL.
show access-list usage asl-slice port <port_#>
Best Regards,
Nikolay
‎04-21-2020 12:25 PM
I know when setting up syslogging, you have to add the slot # to the commands to tell it which switch in the stack it’s supposed to be applied to. It’s probably a similar requirement.
