How to assigned static IP to machine using DHCP server on Summit X430-24t switch?
Arun_Verma
Hello Commumnity,
I have configured DHCP server on Summit X430-24t switch. I want to allocate a dedicated IPs to some servers using DHCP-binding. After going through documentation, I found command "configure ip-security dhcp-binding add ip ip_address mac mac_address {vlan} vlan_name server-port server_port client-port client_port lease-time seconds".
I don't know what is server_port and client_port. There are not much details about it in documentation.
Can anyone please me, how to assign static IPs to the servers using switch DHCP server?
Warm Regards,
Arun
5 REPLIES 5
Chris_H
itā€™s still the same.. those are switches and not meant for more-in-depth DHCP functionality.
ARPcPro
Was there any improvement since this post was created or the dhcp server is still basic?
On my X670-G2 I could not find a way to assign the same IP address to a specific MAC.
Arun_Verma
Thanks Oscark and Henrique for your help.
Henrique
"This commands allows you to add a DHCP binding in order to re-create the bindings after reboot and to allow IP Security features to work with clients having static IP addresses."
As already said by Oscar, this is part of IP-Security feature and not to be used to assign static IP do any devices.
