How to check Serial No. and System No. of EPS from Extreme Switches? Thanks.
Paul11
Contributor
How to check Serial No. and System No. of EPS from its connected Extreme Switches?
Is there any way to check Serial No. and System No. of EPS (External Powersupply) from Extreme Switches.
Thanks.
12 REPLIES 12
Kawawa
Hi Paul, I am using a X460, which gives me an output like the one below:
Switch : XXXXXX-XX-XX XXXXX-XXXXX Rev 2.0 BootROM: 2.0.1.7 IMG: 15.6.1.4
SS-B-1 : XXXXXX-00-X1 XXXXG-XXXXXX Rev 1.0
PSU-1 : EDPS-XXXAB A-S9 XXXXXX-00-03 XXXXE-XXXXX
PSU-2 :
You're on a X250, running version 12. I am not sure you'd see a output similar to what I have probably because the X250 doesn't have a field replaceable (modular) PSU, but again, I am speculating on this one. Will wait and hear back from the team!
Thanks Kawawa, for the information. Yep it might be system model and ver 12. Thanks.
Paul11
Contributor
Thanks Drew,
Appreciate your help very much.
We are using (2x EPS-160 in a 1U Rack) EPS-T External Power Tray
model: 10906
Drew_C
Valued Contributor III
Hi Paul,
I haven't forgotten about this. I've got to dig up the right cable to connect the EPS to the switch. While I'm looking, are you using the EPS-160 or EPS-T? Same cable, just a different External PSU... we have both.
