How to check Serial No. and System No. of EPS from Extreme Switches? Thanks.
Paul11
Contributor
How to check Serial No. and System No. of EPS from its connected Extreme Switches?
Is there any way to check Serial No. and System No. of EPS (External Powersupply) from Extreme Switches.
Thanks.
12 REPLIES 12
Drew_C
Valued Contributor III
Hi Paul,
I don't think you can retrieve the EPS information from the switch, but I could be wrong.
I'll see if I can get our lab team to test this on Monday morning to help be sure.
I also noticed that you're running EXOS 12.1, which is rather old. I'll see if this makes any difference in the results.
Kawawa
show version
In the output, you should see a section showing connected PSUs and their associated serials
Slot-1 x250-sw01.13 # show version
Slot-1 : 800211-00-03 0943G-81649 Rev 3.0 BootROM: 1.0.3.5 IMG: 12.1.3.14
Slot-2 : 800211-00-03 0943G-81622 Rev 3.0 BootROM: 1.0.3.5 IMG: 12.1.3.14
Slot-3 :
Slot-4 :
Slot-5 :
Slot-6 :
Slot-7 :
Slot-8 :
Image : ExtremeXOS version 12.1.3.14 v1213b14-patch1-6 by release-manager
on Tue Sep 8 13:07:40 PDT 2009
BootROM : 1.0.3.5
Slot-1 x250-sw01.14 #
Slot-1 x250-sw01.15 # show version detail
Slot-3 :
Slot-4 :
Slot-5 :
Slot-6 :
Slot-7 :
Slot-8 :
BootROM : 1.0.3.5
Slot-1 PCB INFO: 8FBCPU...0A2 G67225662
Subsystem PCB INFO: 8EVTPA24.1A1 G67292039
Slot-2 PCB INFO: 8FBCPU...0A2 G67225884
Subsystem PCB INFO: 8EVTPA24.1A1 G67291940
Slot-1 x250-sw01.16 #
I cannot see any section showing connected PSUs and their associated serials. Thanks
