How to do Stacking Role from NONE to Backup
Paul11
Contributor
X250e-48p and x250e-48t Stacking. I want to achieve Master and Backup Stack Topology. Please advice me how to configure it. Thanks.
032d3787cab44fd28b45cd9cdacb6d70_RackMultipart20150715-14538-1n2finq-sh_switch_No_Backup_inline.jpg
Slot-1 Stack.1 # show stackingStack Topology is a Ring
Active Topology is a Ring
Node MAC Address Slot Stack State Role Flags
*00:04:96:28:22:1b 1 Active Master CA-
00:04:96:26:64:a9 2 Active CA-
* - Indicates this node
Flags: (C) Candidate for this active topology, (A) Active Node
(O) node may be in Other active topology
Slot-1 Stack.2 #
Slot-1 Stack.2 # sh stack configurationStack MAC in use: 02:04:96:28:22:1b
Node Slot Alternate Alternate
MAC Address Cfg Cur Prio Mgmt IP / Mask Gateway Flags Lic
*00:04:96:28:22:1b 1 1 100 CcEeMm--- Ee
00:04:96:26:64:a9 2 2 50 CcEeMm--- Ee
Slot-1 Stack.5 # sh stack stack-ports
Slot Port Select Node MAC Address Port State Flags Speed
*1 1 Native 00:04:96:28:22:1b Operational C- 10G
*1 2 Native 00:04:96:28:22:1b Operational CB 10G
2 1 Native 00:04:96:26:64:a9 Operational CB 10G
2 2 Native 00:04:96:26:64:a9 Operational C- 10G
Flags: (C) Control path is active, (B) Port is Blocked
Slot-1 Stack.5 #
- Paul
16 REPLIES 16
Patrick_Voss
Hi Paul,
The role coming up as none could me a couple different things. Moving forward I would recommend looking at the logs to see if it tells you why or use the "show slot" output. It could be a license or image mismatch. If you would like to post these outputs for evaluation I would be happy to take a look.
Thanks Patrick,
Slot-1 Stack.4 # show slot
Slots Type Configured State Ports
Slot-1 X250e-48p X250e-48p Operational 50
Slot-2 X250e-48t X250e-48t Failed 50
Slot-3 Empty 0
Slot-4 Empty 0
Slot-5 Empty 0
Slot-6 Empty 0
Slot-7 Empty 0
Slot-8 Empty 0
Slot-1 Stack.4 #
