Hi David,
The EXOS version i am using is 22.4.1.4. All end devices have static IP addresses, and i can see them in the upstream switches, they dont have any connectivity problems.
On my original post you can see that port 3:23 is with link, but the iparp hasnt learn anything from that port, this can be confirmed with the command you suggested.
Slot-1 SEDUCA050100.1 # sh iparp port 3:23
VR Destination Mac Age Static VLAN VID Port
Dynamic Entries : 210 Static Entries : 0
Pending Entries : 0
In Request : 36704719 In Response : 34498
Out Request : 5403 Out Response : 3436
Failed Requests : 0
Proxy Answered : 0
Rx Error : 0 Dup IP Addr : 0.0.0.0
Rejected Count : 33098174 Rejected IP : 147.96.23.2
Rejected Port : 1:49 Rejected I/F : Docencia
Max ARP entries : 8192 Max ARP pending entries : 256
ARP address check: Disabled ARP refresh : Enabled
Timeout : 20 minutes ARP Sender-Mac Learning : Disabled
Locktime : 1000 milliseconds
Retransmit Time : 1000 milliseconds
Reachable Time : 900000 milliseconds (Auto)
Fast Convergence : Off If i configure and Vlan assign an ip address to that vlan, i can see the IP of the connected device, the problem arises when i put the default port configuration that i use on my network, this is when the iparp loses all information off the connected device. This is the deafult port configuration:
Slot-1 SEDUCA050100.2 # sh conf | in "3:23"
disable snmp traps port-up-down port 3:23
configure port 3:23 rate-limit flood broadcast 120 out-actions log trap
configure port 3:23 rate-limit flood multicast 120 out-actions log trap
configure port 3:23 rate-limit flood unknown-destmac 120 out-actions log trap
configure vlan DAPs add ports 3:23,3:45-47,4:10-13 untagged
configure port 3:23 link-flap-detection on
configure port 3:23 link-flap-detection interval 60 threshold 5
configure port 3:23 link-flap-detection action add log trap
enable mac-locking ports 3:23
configure mac-locking ports 3:23 first-arrival limit-learning 1
configure mac-locking ports 3:23 first-arrival aging enable
configure mac-locking ports 3:23 trap violation on
configure mac-locking ports 3:23 log violation on
configure policy rule admin-profile port 3:23 mask 16 port-string 3:23 admin-pid 8
disable edp ports 3:23
disable lldp ports 3:23
enable nodealias ports 3:23
configure nodealias ports 3:23 maxentries 20
configure stpd s0 ports link-type edge 3:23
configure stpd s0 ports edge-safeguard enable 3:23
configure stpd s0 ports bpdu-restrict enable 3:23I dont have any problem on the switches that are on EXOS 21.x.x version and all of them have the same configuration regardless of the EXOS version.
Let me know if i was clear enough with my explation
Br,
Gonçalo Reis
