‎03-14-2016 10:30 AM
I have a customer who has a core of Extreme , and Juniper edge .
We seem to have an issue with Mlag.
The config looks OK , only thing different to my configuration is that the ISC is in its own VR, I do not see an issue with that ..
The problem that is being reported , is that the edge switches ( juniper when configured for AE0, the transfer of data is extremely slow.
Remove one of the mlag links and it all speeds up to an acceptable level.
We are not running LACP..
Juniper Edge config.
set interfaces ae0 description xe-uplinks-LAG set interfaces ae0 aggregated-ether-options minimum-links 1
set interfaces ae0 aggregated-ether-options link-speed 10g
set interfaces ae0 unit 0 family ethernet-switching port-mode trunk
set interfaces xe-0/1/0 ether-options 802.3ad ae0
set interfaces xe-0/1/1 ether-options 802.3ad ae0
Extreme config :
One side only ..
create vr "VR-MLAG-ISC"
create vlan "MLAG-ISC" vr VR-MLAG-ISC
configure vlan MLAG-ISC tag 6
configure vlan "MLAG-ISC" qosprofile QP5
configure vlan MLAG-ISC add ports 1:39 tagged
configure vlan MLAG-ISC ipaddress 10.10.10.1 255.255.255.252
disable iproute ipv4 compression vr VR-MLAG-ISC
disable iproute ipv6 compression vr VR-MLAG-ISC
create mlag peer "CL-MLAG"
configure mlag peer "CL-MLAG" ipaddress 10.10.10.2 vr VR-MLAG-ISC enable mlag port 1:43 peer "CL-MLAG" id 1
enable mlag port 1:44 peer "CL-MLAG" id 2
enable mlag port 1:45 peer "CL-MLAG" id 3
enable mlag port 1:46 peer "CL-MLAG" id 4
enable mlag port 1:47 peer "CL-MLAG" id 5
enable mlag port 1:48 peer "CL-MLAG" id 6
Ok this is more than I would configure normally for MLAG..(QOS IProute Compression )..
My main question is :
What hashing algorithm does Mlag use , its construction and can it be modified ,
I expect the issue to be the difference between Juniper and Extreme Algorithms ... well I hope it is , if this cannot be resolved , the customer will be returning to EAPS.
Many Thanks
Rod
Extreme config :
One side only ..
Many Thanks
Rod
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎03-15-2016 12:19 PM
Hi Rod, I'm not sure if that will fix the issue. However, that change has fixed a similar problem last year.
I know this is mandatory when configuring LACP only, but it's a good option to try.
20 REPLIES 20
‎03-15-2016 10:32 AM
Hi
Ok so the suggestion for the uplink 1:43 is to set it to sharing with only one member and then change the hash to l3 .. sort of what you do mlag when using LACP
‎03-14-2016 07:09 PM
Rod, when configuring 802.3ad on Juniper side, is there any algorithm option like L2, L3, L3_L4 similar to those in EXOS?
Just want to share that I saw a similar behavior (slow data transfer) last year in another vendor connecting to an MLAG pair and it was fixed using L3 sharing algorithm on both link ends.
In that case both side of the links were using Static LAG even using 1 port (I know this is not needed) and we changed the algorithm on both ends to a higher level (L3/L3_L4).
Hope this give some clue.
‎03-14-2016 02:17 PM
Hi Rod,
When you have this second port active how does the TOP output look? Is there a particular process running high on either of the MLAG switches?
Im hoping to get out there tomorrow ... what am I looking for MXBCM ?
