need help For Extreme X450e-48P switch configure UDP data
Mukesh
Extreme Switch X450e-48p help
8 REPLIES 8
Mukesh
ok i will do then i will reply after testing it
tommorrow i will go to the site where i installed it
Zdeněk_Pala
Thank you for description.
I guess the issue is with multicast. the default behavior on EXOS switch is that multicast is not passing through. Enable IGMP snooping on the vlan. Commands should look like:
enable igmp snooping "Default" where "default" is the vlan name where you have the multicast traffic.
Z.
Regards Zdeněk Pala
Mukesh
Sir I have 8 Udp Adrress data Carrying each Ip 40 Mbps From 8 encoder ts over udp ip output
The data on switch 2,3,4,5,6,7,8,9 ports are showing. I want to carry my al udp streaming ip address over 1 number port of switch. theproblem i am facing that the video in traffic is showing on switch but video out traffic is not passing through any port of switch. i do not know how to configure udp data on switch. That is my cable tv headend multicast ip addresss
Zdeněk_Pala
If you want help from the community then you need to define your problem.
If you want help from the company then contact technical assistance center.
Not sure how to proceed with the problem you described.
Good luck!
Regards Zdeněk Pala
