OSPF Init stuck
OSPF Init stuck
Julian_Eble
New Contributor II
Hello Community,
I'm in a odd journey trying to understand what's going on here.
There are two Extreme switchs connected by 2 10G ports running LACP.
The master port is UP and the member also is UP and everything is okay with LACP and OSPF between them.
But if the master port is disabled, the OSPF get stucked into Init state.
I tried to took off the port from the sharing and tried to solo running the ospf , but it didn't worked.
The stranger thing here is if that member port is in the sharing group it ran fine, without any loss.
What should I do? Any advices?
Thanks 
12 REPLIES 12
Alexander,
Somehow the interface was with ipmcforwarding to-cpu off.
Enabling it solved the problem, thanks!
Julian_Eble
New Contributor II
newly vlan create to check that, problem still happening.
the switch has just one acl but is for another port to meter and shape a customer.
Alexander_Roman
Is there any acl on port or vlan where ospf deployed? If yes, try to remove it.
Daniel_Coughlin
I would have to leave that to my EXOS teammates to comment on.
Julian_Eble
New Contributor II
Hello Daniel,
What do you mean about port level? Is there a way to tpcdump that?
THanks
