Power fault on x440-8p port connected to PoE AVB speaker
‎01-14-2018 04:26 PM
I have an x440-8p switch which I have been using successfully with Ethernet AVB audio devices. Recently I tried connecting to Ethernet AVB PoE speakers without success (amber/green port light flashing). I have connected to the management port and ensured that inline-power is enabled on all ports. I have shown inline-power info for one of the faulty ports, and see that there is a UV/OV fault. The operator limit for the port is 30 watts, but I see that the Max Allowed Power field is 0.0 watts. Could this be the issue, and if so is there a command to change this value? Thanks!
7 REPLIES 7
‎01-18-2018 11:56 AM
Thanks again Doug - will do!
Yes, that would probably be the best method to speed up the resolution of your issue.
Doug Hyde
Director, Technical Support / Extreme Networks
‎01-18-2018 11:47 AM
I would suggest if you were not able to resolve this yet that you contact the GTAC so someone can help you out.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
Doug Hyde
