Problem with CPU and memory monitoring (MIBs)
eyeV
New Contributor III
Hi everybody.
I have some troubles with CPU and memory monitoring on the Solarwinds monitoring system. I've gotten interface statistics, sysname, sysdescription, but I haven't found CPU and memory information.
Then I try to find ExtremeXOS MIBs, but unfortunately I haven't found it too.
Where can I find XOS MIBs? Can you give me advice about SNMP monitoring?
13 REPLIES 13
Drew_C
Valued Contributor III
I'm not very familiar with the ins and outs of Solarwinds... Can you import the EXOS MIB into the program to help make configuration easier?
Davor
We have issue with pooling system info (cpu, mem etc.) from X8 with Solarwinds. I also tryed to pull with Paessler and some other snmp tools. some of those OIDS are correct but some do not show usable info.
I have also troubles importing Extreme Networks MIB file to lot of SNMP tools. What is deal with that. What MIB/OID tool you use that can import Extremes MIB file correctly?
What OID's to use on X8?
eyeV
New Contributor III
I've found OIDs in my snmpwalk list. Anyway OID .1.3.6.1.4.1.1916.1.32.1.6.0 doesn't work, but other OIDs from your list works perfectly.
Sumit_Tokle
Contributor
Can you let us know what information you found?
eyeV
New Contributor III
Sorry, I've found it.
