‎07-25-2021 05:19 AM
In the EXOS Hardware Installation Guide;
In the IRIS, the QSFP+ DAC are available from 0.5m to 5m lengths.
Won't the QSFP+ DAC work on the X590 switches for V160 stacking?
Solved! Go to Solution.
‎07-25-2021 09:54 AM
Aah, now I understand. 😄
Well, the Stacking section in the EXOS User Guide (ExtremeXOS® User Guide Version 31.3 > Configuring Stacked Switches > Introduction to Stacking > Available Stacking Methods) also states that QSFP+ is supported:
This is only the case for EXOS 30.2 and above. For 22.6 and 22.7 QSFP+ is not listed for X590, only QSFP28.
I would conclude that QSFP+ is supported, with 30.2+.
Where exactly did you find the information (screenshot) in your initial post?
‎07-25-2021 10:02 AM
It's on the page 203 of the EXOS Hardware Installation Guide.
So now it's confirmed. Great thanks! ![]()
‎07-25-2021 09:35 AM
Dear Stefan,
I need to confirm this because the compatibility matrix shows this; says it’s compatible.
‎07-25-2021 09:29 AM
Hi
I think it’s pretty clear. Only QSFP28 possible, not QSFP+.
Best regards
Stefan
