SFP (SX Media) not activating on 15.7.1.4
‎04-07-2015 06:55 PM
On a X460G2-48p-GE4 the SFP ports wont activate after I upgraded the firmware from 15.6.2.12 to 15.7.1.4
If I downgrade to 15.6.2.12 the port starts up again and the uplink connects to the core switch.
I checked the release notes and cannot find any info, on the logs it when I pull the sfp out and put it back in it just shows:
04/07/2015 14:42:14.33 : Media SX is inserted into Port 49
The SFP's were bought from Enterasys and used on C5 switches. The make on the SFP's are JDSU (JSP-12S0AA1) PN 52P6529
21 REPLIES 21
‎07-09-2015 01:21 PM
Hi Tino,
I see the fix made it into 16.1 under another CR number (xos0060179). That explains why you see it working there.
Also, I noticed an update to the CR Andrew mentioned (xos0061283) - The fix is now expected be included in 15.7.2.
‎05-14-2015 12:42 PM
Thank you very much Andrew. That has been extremely helpful. GTAC told me my SFP's were not supported.
‎05-14-2015 12:39 PM
Tino,
Yes, the behavior thus far in our testing indicates the unexpected behavior is particular to EXOS 15.7. CR xos0061283 has been assigned to the issue. The software fix is currently scoped for EXOS 15.7.3.
-Andrew
-Andrew
‎05-14-2015 12:35 PM
X460G2-48p-G4.2 # debug hal show optic-info port 49 Port 49
SFP or SFP+: SFP
Signal: present
TX Fault: no
SFP/SFP+ Vendor: WTD
SFP/SFP+ Part Number: RTXM191-552
SFP/SFP+ Serial Number: BP145100790163
SFP/SFP+ Manufacture Date: 141219
SFP/SFP+ Type: SFP/SFP+
Connector: LC
GE Compliance: 1000BASE-SX
Wavelength: 850
GBIC supports DDMI. MonitorType: 68
X460G2-48p-G4.3 # show port 49
Port Summary Monitor Thu May 14 12:06:13 2015
Port Display VLAN Name Port Link Speed Duplex
# String (or # VLANs) State State Actual Actual
49 Default E R
SFP or SFP+: SFP
Signal: present
TX Fault: no
Connector: LC
Wavelength: 850
49 Default E R
‎05-14-2015 12:34 PM
Today I tested a Extreme 1000BASE-SX SFP (10051H) and that does not work either on 15.7.1.4
X460-G2-48p-GE4 no SFP's work on 15.7.1.4
X460-G2-48p-10GE all SFP's work on 15.7.1.4
The problem seems to be limited to X460-G2-48p-GE4 on 15.7.1.4
