SSH and Web management acces of switch from LAN
Peter_Millard
New Contributor II
Hi there,
I'm new to ExtremeOS, im trying to setup SSH and Web management of an X450a-24t.
I have given the mgmt vlan an ip address.
And i have created a new vlan, vlan 4094 (ManagementVLAN) an ipaddress.
But i cant access either from the lan.
Can help with a step by step guide on how to configure this correctly?
Here is a screen grab of my vlan config.
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
Default 1 --------------------------------T------------ ANY 0 /26 VR-Default
ManagementVLAN 4094 --------------------------------------------- ANY 0 /0 VR-Default
Mgmt 4095 192.168.155.4 /16 ------------------------- ANY 1 /1 VR-Mgmt
Many thanks,
Peter
10 REPLIES 10
Patrick_Voss
Hello Peter,
This is difficult to say. The ports and VLAN assignment is part of the design of the network. The tagging is used to send traffic L2 across VLANs with a common link. This way the other side (Ie. another switch, typically) can know what VLAN that traffic is associated with. You can only have one VLAN untagged per port.
Peter_Millard
New Contributor II
Hi yes enable web http has been run.
So do i just need to add all of the ports as tagged into the other valns then?
BradP
Also, did you "enable web http/https"?
Patrick_Voss
The ports are not added into the other VLANs. The VLANs will not become active unless there is an active port added to them.
