Summit X670V-48t - Switchport stuck in ready status
Claudio
Product Model: Summit X670V-48t-FB-AC
Software Version: 16.1.3.6
Ethernet Switchport 1:7 remain in ready status even if a device is connected on it. I tried many different cables and devices but the Switchport doesn’t come Active but everything works correctly in all other Switchports. I also tried to reboot the switch without any results. I think that Switchport is broken. My question: how can I verify that Switchport is broken? Is there a way to understand with some "show" commands that there is a physical issue on that Switchport?
Thank you in advance to all the Community
Best Regards
Claudio
11 REPLIES 11
Jarek
New Contributor II
Hi Claudio,
check your switch config, maybe you have disable auto-negotiation on that port ?
What you see after:
sh ports 1:7 information detail | inc "Admin state"
Please see also:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-To-Hard-Code-a-Port-s-Speed-and-Duplex...
Jarek
Ariyakudi_Srini
Hi Claudio,
There is no explicit command as such to inform if the port has failed or not. From your information, it indeed looks like a port failure. Additionally the port LED can can notify the status with the LED lighting up or not when connecting device to the suspected port.
