When creating a vlan, I get a loop after 1 hour in network. How can I check it?
MUNIR_ENG
New Contributor III
hello Guys , I have added new switch type Summit X450-24x DC in my network , when i creating any Vlan after 1 hours loop happen in network , why that happened , Is there commanded or method to shows me where the defect was?
18 REPLIES 18
Thiago_da_Silva
Hello,
You should segment the network.
Taking the cables on to one.
You will see if there is one problem in your network.
you have create one instance Spanning tree.
create stpd EX: stpd_S0
config add vlan ports dot1d
config tag
config mode dot1w
enable stpd
enable stpd
Jeremy_Gibbs
Contributor
Assuming you are running stp,
show stpd s0 ports blocked-ports
show stpd s0 ports non-forwarding-reason
show stpd s0 ports detail
These commands might help you solve your problem.
MUNIR_ENG
New Contributor III
I appreciate your feedback, but how I can doing test without Cable?
Thiago_da_Silva
I believe that you should do test without the cables of networks.
If not working.
The loop can be into your network.
You should do update in switch.
If you have problem, please write me.
