X435-24P-4S IGMP Query Issues
‎08-22-2023 03:29 PM
So we are using s X435 with the AVB feature lic installed with our new AV system. The system is using visionary duet2 encoders/decoders along with Crestron components. I setup a AV VLAN with IGMP query and snooping, but the video will not hold a signal according to AV install vendor, if only works if he supplies a IGMP query from his laptop. I assigned VLAN IP to IP 192.168.1.1. The ports not assigned to this AVB VLAN or using both our VOIP and Data VLANs.
I am not sure what we are missing. There solution is to add a router that can perform IGMP. But if I understand it right the switch should be doing this when the VLAN has an assigned IP. I have provided the outputs from these commands <sh igmp vlan TAVB>, <sh vlan tavb>, <sh port 2 info det>.
sh igmp vlan tavb
Query Interval : 125 sec
Max Response Time : 10 sec
Last Member Query : 1 sec
Robustness : 2
Interface on VLAN TAVB is enabled and up.
inet 192.168.1.1/24
Locally registered multicast addresses:
224.0.0.2 224.0.0.22
Learned multicast addresses(Last Querier=192.168.1.1):
s = static igmp member
Querier UpTime: 33 minutes 11 seconds
Flags:
IP Fwding NO IPmc Fwding NO IGMP YES
IGMP Ver V2 Snooping YES Proxy Query YES
XmitRtrAlrt YES RcvRtrAlrtReq NO
sh vlan TAVB
VLAN Interface with name TAVB created by user
Admin State: Enabled Tagging: 802.1Q Tag 100
Description: None
Virtual router: VR-Default
IP Anycast: Disabled
IPv4 Forwarding: Disabled
IPv4 MC Forwarding: Disabled
Primary IP: 192.168.1.1/24
IPv6 Forwarding: Disabled
IPv6 MC Forwarding: Disabled
IPv6: None
STPD: None
Protocol: Match all unfiltered protocols
Loopback: Disabled
NetLogin: Disabled
QosProfile: None configured
Egress Rate Limit Designated Port: None configured
Flood Rate Limit QosProfile: None configured
Suppress ARP: Disabled
Suppress ND: Disabled
Proxy ARP: Entry required
Ports: 22. (Number of active ports=14)
Tag: *1, *2, 3, *4, *5, *6, *7,
8, 9, *10, *11, 12, *13, *14,
*15, 16, *17, 18, *19, *20, 21,
22
sh port 2 info det
Port: 2
Virtual-router: VR-Default
Type: UTP
Random Early drop: Unsupported
Admin state: Enabled with auto-speed sensing auto-duplex
Link State: Active, 1Gbps, full-duplex
Link Ups: 1 Last: Tue Aug 22 15:37:01 2023
Link Downs: 0 Last: --
VLAN cfg:
Name: Default, Internal Tag = 1, MAC-limit = No-limit, Virtual router: VR-Default
Name: TAVB, 802.1Q Tag = 100, MAC-limit = No-limit, Virtual router: VR-Default
Port-specific VLAN ID: 100
STP cfg:
s0(enable), Tag=(none), Mode=802.1D, State=FORWARDING
Protocol:
Name: Default Protocol: ANY Match all protocols.
Trunking: Load sharing is not enabled.
EDP: Disabled
EEE: Disabled
ELSM: Disabled
Ethernet OAM: Disabled
MACsec: Disabled
Learning: Enabled
Link-Flap Detection: Disabled
Unicast Flooding: Enabled
Multicast Flooding: Enabled
Broadcast Flooding: Enabled
Jumbo: Enabled, MTU= 9216
Flow Control: Rx-Pause: Enabled Tx-Pause: Disabled
Priority Flow Control: Disabled
Reflective Relay: Disabled
Link up/down SNMP trap filter setting: Enabled
Egress Port Rate: No-limit
Broadcast Rate: No-limit
Multicast Rate: No-limit
Unknown Dest Mac Rate: No-limit
QoS Profile: None configured
Ingress Rate Shaping : Unsupported
Ingress IPTOS Examination: Disabled
Ingress 802.1p Examination: Enabled
Ingress 802.1p Inner Exam: Disabled
Ingress 802.1p Priority: 0
Egress IPTOS Replacement: Disabled
Egress 802.1p Replacement: Enabled on QP1 QP4 QP8
NetLogin: Disabled
NetLogin port mode: Port based VLANs
Smart redundancy: Enabled
Software redundant port: Disabled
IPFIX: Disabled
auto-polarity: Enabled
Shared packet buffer: default
VMAN CEP egress filtering: Disabled
Isolation: Off
PTP Configured: Disabled
Time-Stamping Mode: None
Dynamic VLAN Uplink: Disabled
VM Tracking Dynamic VLANs: Disabled
‎08-23-2023 12:52 AM
Hi @Joe10 ,
Can you run the following commands on your switch and provide me the result ?
show version
show switch
show license
show ports vlan
Regarding your issue, you can see below several link that can help you :
IGMP Querier :
https://extremeportal.force.com/ExtrArticleDetail?an=000080842
AVB :
https://support.biamp.com/Tesira/AVB/Enabling_AVB_on_Extreme_Networks_switches
https://extremeportal.force.com/ExtrArticleDetail?n=000001150
https://extremeportal.force.com/ExtrArticleDetail?an=000082155
KR
Kevin
‎08-23-2023 07:11 AM
Switch : 800982-00-08 2219G-00660 Rev 08 BootROM: 2.0.0.6 IMG: 30.7.1.1
Image : ExtremeXOS version 30.7.1.1 30.7.1.1-patch1-86 by release-manager
on Wed Dec 16 10:21:32 EST 2020
BootROM : 2.0.0.6
Diagnostics :
Certified Version : EXOS Linux 4.14.170, Extreme Networks FIPS Object Module 2.0.16a
Build Tools Version : exos-arm32-sdk-2.5.3.1.1
sh sw
SysName: TA_AV_X435G2
SysLocation:
SysContact: https://www.extremenetworks.com/support/
System MAC: F4:CE:48:F9:83:BB
System Type: X435-24P-4S
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Current Time: Wed Aug 23 08:15:35 2023
Timezone: [Auto DST Enabled] GMT Offset: -420 minutes, name is not set.
DST of 60 minutes is currently in effect, name is not set.
DST begins every second Sunday March at 2:00
DST ends every first Sunday November at 2:00
Boot Time: Tue Aug 22 15:35:57 2023
Boot Count: 29
Next Reboot: None scheduled
System UpTime: 16 hours 39 minutes 38 seconds
Current State: OPERATIONAL
Image Selected: primary
Image Booted: primary
Primary ver: 30.7.1.1
patch1-86
Secondary ver: 30.7.1.1
patch1-86
Config Selected: primary.cfg
Config Booted: primary.cfg
Config Automatic: NONE (Disabled)
primary.cfg Created by ExtremeXOS version 30.7.1.1
342486 bytes saved on Tue Aug 22 16:51:55 2023
LAA MAC: Locally Administered MAC Address Disabled
sh lic
Enabled License Level:
Value Edge
Enabled Feature Packs:
DirectAttach AVB
sh port vlan
Untagged
Port /Tagged VLAN Name(s)
1 Untagged None
Tagged TAVB
2 Untagged None
Tagged TAVB
3 Untagged None
Tagged TAVB
4 Untagged None
Tagged TAVB
5 Untagged None
Tagged TAVB
6 Untagged None
Tagged TAVB
7 Untagged None
Tagged TAVB
8 Untagged None
Tagged TAVB
9 Untagged None
Tagged TAVB
10 Untagged None
Tagged TAVB
11 Untagged None
Tagged TAVB
12 Untagged None
Tagged TAVB
13 Untagged None
Tagged TAVB
14 Untagged None
Tagged TAVB
15 Untagged None
Tagged TAVB
16 Untagged None
Tagged TAVB
17 Untagged None
Tagged TAVB
18 Untagged None
Tagged TAVB
19 Untagged None
Tagged TAVB
20 Untagged None
Tagged TAVB
21 Untagged None
Tagged TAVB
22 Untagged None
Tagged TAVB
23 Untagged Data
Tagged voice
24 Untagged Data
Tagged voice
25 Untagged Data
Tagged voice
26 Untagged Data
Tagged voice
27 Untagged Data
Tagged voice
28 Untagged Data
Tagged voice
