X440-G2-24p-10GE4 High Fan speed
Marcel1
I have 2 of these Switches stacked on eachother.
The top one is more under load most of the time and is currently running at 89F(31C)
All 4 fans are between 8000RPM and 9000 RPM
Why is it that they would be spinning at that rate? and why only this one switch?
Would it be due to the temp, or higher usage?
the Switch below this one is noisy at all. and is also running at 87F(30C)
Fan speed: 2160RPM
Any feedback would be greatly appreciated.
X440-G2-24p-10GE4
version 21.1.1.4 21.1.1.4
Thanks
1 ACCEPTED SOLUTION
10 REPLIES 10
FredrikB
Contributor II
The post referenced above says:
"They found the problem and will resolve it in EXOS 22.7.1-Patch1 which is scoped for mid of October [2019 presumably] (CR xos0075492)"
Going back to the BD10k days and several other switch models, it is, sadly, a fact that fan issues come and go with various releases. Keep complaining and make sure the TAC gets to know about it. Check your fans before upgrades if noise is critical for you and see how the new software handles the fans. If different, complain. Sometimes they claim to have detected a problem with a low fan speed so they were forced to increase the minimum speed, but you can always create a case for it.
/Fredrik
Narayanan__Kart
Hi Marcel,
Did you get a chance to check the article?
Please let us know if you have any further queries?
Regards,
Karthikeyan
Narayanan__Kart
Hi Marcel,
you can follow the below article for the upgrade procedure.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Obtain-and-Upgrade-EXOS
Please let us know if you have any further queries.
Regards,
Karthikeyan
